1996 LS400 Dash Light Replacement?
Old 10-09-16, 11:41 PM
winter4w
winter4w's Avatar
Question 1996 LS400 Replace dash lights?
Hello,
So some of my dash lights are out and I was wondering how hard is it to replace them? The lights that are out are Drive, the Premium Fuel only, and I believe the top of the speedometer. Also I would prefer to get the OEM bulbs so if you can also provide the part number that would be awesome
Thanks
Old 10-10-16, 03:39 PM
winter4w
winter4w's Avatar
Question 1996 LS400 Dash Light Replacement?
So I am trying to see what lights are out on my dash. So far all I can see is the Drive light when you put it in drive. Above the fuel indicator it shows Premium Unleaded Fuel Only. Is there suppose to be a light behind there also or no?
Thanks
- winter4w
Old 10-11-16, 03:31 PM
timmy0tool
timmy0tool's Avatar
when you turn on your car, the instrument cluster goes through it's checks and turns on all the important lights for a second (like check engine, oil level, brake, etc). unfortunately not all lights are triggered. from this pic, it looks like the "premium unleaded fuel only" is lit.
http://cdn3.volusion.com/ojrvp.wzvke...jpg?1389174049
generally speaking, don't think there is a light in certain spots just bc you see an outline. these cars were available around the world and certain cars depending on country had spots in the cluster for other features we don't have.
Old 10-11-16, 11:06 PM
winter4w
winter4w's Avatar
Ok thanks
Old 10-12-16, 05:58 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
duplicate threads merged.
The small lights (for the symbols/etc) are normal bulbs that you can buy froma delear. The main dash cluster lighting however is NOT bulb or LED based and cannot be aesily repaired by the end-user.
I would advise you to post a picture of the lights you're talking about so we can be sure to give correct advice.
Old 10-12-16, 06:01 PM
winter4w
winter4w's Avatar
Ok thanks sorry for the multi thread I am a bit new here . Looking into it I guess its only my D (Drive) light that is out. I will ask the dealer and see how much the bulb may cost
Thanks
- winter4w
PhilipMidd
07-03-18 07:02 PM
nickels626
16
03-01-11 11:54 AM
stroker
10-07-07 09:04 AM
ZeekGS300
GS - 1st Gen (1993-1997)
12-10-05 09:34 PM
(f)-LEX-ible
12-09-02 04:08 PM
Quick Reply: 1996 LS400 Dash Light Replacement?
