1996 LS timing belt job
Old 08-14-16, 04:37 PM
wbzautocus
wbzautocus's Avatar
Default 1996 LS timing belt job
I did some searching but couldn't find what I was looking for. I have to do a water pump/timing belt 96 LS all parts are on the way OEM lexus parts 16-18 parts total I am seeing if anyone has a link or good way to find on this forum. I have found a 1990-1994 play by play guide but not 96 or is 90-94 the same for 96 engine wise, thanks in advance
Old 08-14-16, 05:08 PM
Banshee365
Banshee365's Avatar
This is probably the most common. --->http://www.lexls.com/tutorials/engine/timingbelt.html
I use the factory manual which is a slightly different technique. It has your setup the crank and cams to further prevent any valve interference if you move things around during the job. If you don't go crazy with that way listed in that tutorial you'll be fine. Where did you order all of the OEM parts from. I used the Aisin kit from RockAuto for $175 which included parts from the OE without the Toyota box. Included was a bonded gasket for the water pump so I didn't use the sealant like shown in the tutorial. The crank bolt is torqued to 181 ft/lb so it's really tight. You'll want to either have the special crankshaft holding tool to torque the bolt down or lock the crank at the flywheel.
Old 08-14-16, 05:24 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
This tutorial does not apply properly to 95-97 LS400s.
There are a couple tutorials floating around here, I forget if we have one linked in the FAQ but I would start there.
Old 08-14-16, 08:21 PM
jaaa
jaaa's Avatar
I did my 1996 ls400 last month and used the one banshee listed below. It works well enough. I made marks on my old belt before I took it off to be sure I knew where it lined up on the crank. I also had my bank one cam spin on me as I was putting on the belt, but just rotated it back. All in all, the 90-94 one worked quite well.
Old 08-15-16, 11:40 AM
brybo86
brybo86's Avatar
Default try this
my thread is here including any tips I thought of along the way. please report back if (when) you need further help
B
https://www.clublexus.com/forums/ls-...s400-172k.html
Vadim540i
SC- 1st Gen (1992-2000)
18
06-18-14 07:31 PM
ivnnln
12-23-12 09:53 AM
rabbits
10-12-10 05:14 PM
jtgs400
04-25-08 02:28 PM
LSPiNoY
Maintenance
01-25-06 09:29 PM
Quick Reply: 1996 LS timing belt job
