Replacing exterior door handle rubber cushions
The exterior door handles on LS400 use rubber cushions to dampen the door handle plate when it retracts into the handle assembly.
The front rubber cushions were brittle on the 99 LS400 so decided to replace all 8 (two/door handle).
Individual cushion for 1999 LS400 depicted. Requires two per exterior door handle.
Rubber cushion easy to access without removing door handle assembly.
Carefully extract by gripping rubber cushion with small needle nose pliers. The tails separated from all front door bumpers...but not the rears.<br/><br/>The handles sound a little quieter when closing.<br/><br/>Coat new parts with **** Etsu grease.<br/><br/>
Michael88
10-09-18 05:18 PM
Deuce_B
20
02-19-12 08:06 AM
