Heat stays on
Old 04-02-16, 10:24 AM
Rusty84
Rusty84's Avatar
Default Heat stays on
Hello I have a 1990 LS 400 I'm having trouble getting my control panel to work its like my heat is stuck on even if I unplug the panel the heat still blows out I have tired three different panel as soon as I connect them the heat pops on I'm not able to control nothing on the panel the lights just blink green some one please help it's starting to get HOT in Texas
Old 04-02-16, 02:19 PM
oldskewel
oldskewel's Avatar
Does the fan blow hot air, or does hot air come out even though the fan is off?
Old 04-02-16, 05:15 PM
dicer
dicer's Avatar
Does the heat control valve work? The one above the right hand valve cover.
Old 04-02-16, 07:13 PM
Rusty84
Rusty84's Avatar
I unplug the panel but hot air still comes out the vent it was blowing out cold air before I change my thermostat nothing on all three panels work only the switch to control to blow out the top are bottom that's it pls help
Old 04-02-16, 08:37 PM
oldskewel
oldskewel's Avatar
Is the hot air being blown out by the fan, or is it coming out while the fan is not blowing? (2nd try)
Old 04-02-16, 09:49 PM
Rusty84
Rusty84's Avatar
It's coming out while it's off it's heat blowing while I'm driving the car it's bad in day time around 4-7pm
Old 04-02-16, 10:37 PM
oldskewel
oldskewel's Avatar
OK, so that is a "feature" of the HVAC systems in these cars. When the HVAC control is on, and you dial in a temperature, it will adjust the heater valve accordingly to make it hot. For example, it may set the heater valve wide open so the heater core gets hot.
Then if you turn the HVAC system off (or unplug the whole thing like you did), the heater valve is still in the same full-hot position if that's where it happened to be at the time you turned HVAC power off. When you then drive around, the air pressure from driving will force (even without the fan blowing) air through the heater core and then through the vents. So you'll be getting hot air out even though you might think the HVAC should be completely off.
This actually is a nice feature, allowing you to get some heat or fresh air without having the fan running - nice and quiet.
If your HVAC control is dead and you're just looking to stop the heat while you get it fixed, I recommend you find the heater valve that dicer referred to. Maybe you can manually change it from full hot to full cold.
Old 04-03-16, 01:11 AM
Rusty84
Rusty84's Avatar
What about the blend door could that be a issue
Old 04-03-16, 06:37 AM
billydpowe
billydpowe's Avatar
why are you worried about the blend door, did you get in there and damage it?? if not, go do what oldS said and manually close the valve and cut off the water...
Old 04-03-16, 02:34 PM
Rusty84
Rusty84's Avatar
I'm just trying to get my a/c working the compressor comes on but no cool air
Old 04-05-16, 08:54 PM
Rusty84
Rusty84's Avatar
I close the heater value thanks it feel much better now
Old 04-06-16, 01:37 PM
billydpowe
billydpowe's Avatar
you need to check craigslist and find a parts car with a good control unit and fix it...
Old 04-06-16, 03:13 PM
Rusty84
Rusty84's Avatar
I have bought three already they all do the samething so I'm thinking it's a short are electrical
Old 04-06-16, 03:23 PM
dicer
dicer's Avatar
What you need to do is the diagnostic for the climate control system, its kind of involved and I think someone posted a how to on it some place. I think your problem is the servo motor that operates the heat control valve, not the actual climate control unit. The self test should isolate the problem for you. And then its not so hit and miss.
Old 04-06-16, 04:32 PM
Rusty84
Rusty84's Avatar
OK I'm looking into it now good looking
Quick Reply: Heat stays on
