1998 LS400 24F VS 27F battery
Old 03-21-16, 06:29 AM
KJG92
KJG92's Avatar
Originally Posted by python
take that battery out..the 27 is the biggest battery for ur car and should be used...ur shooting urself in the foot using a pos 24. there r 3 battery companies...east penn,exide and johnson control. that ac delco was made by one of the 3. east penn is by far the best..then exide..jc has gone down hill in my opinion as we get a lot of defects since we switched from exide.
Battery works great and will outlast our ownership so it will stay where it is and will be fine. It had a 35 in it from the PO and it was only a year old and was a advanced auto parts brand. They would not take it back cause it still held 450 ca out of the 650 it was rated for. You could park the car 3 days and the battery would be dead. Did a parasitic draw test on the car and it was within spec. Put in the new battery and it has been great ever since. It actually seems to be running much better as well.
Old 03-21-16, 07:22 AM
python
python's Avatar
ur going to put stress on ur starter and alternator. do what u want,and btw..hot and cold weather will have more of an adverse effect on ur battery. a perfect battery is 12.6. talk to me in another 6 months after ur having issues during the hot summer months..good luck.
24f 600 cca
27f 710 cca
Old 03-21-16, 07:01 PM
KC98LS
KC98LS's Avatar
Update: put in the 27F.
850 CA 700CCA, exact same as the 24F I replaced it with.
27F fits like a glove, no noticeable size difference between it and a 24F
apham8 (11-11-23)
Old 03-21-16, 09:00 PM
python
python's Avatar
got two members names mixed up! duh
Old 03-22-16, 06:47 AM
I'mStock
I'mStock's Avatar
Width is different.
Old 03-22-16, 08:39 AM
hyperopt
hyperopt's Avatar
Awesome!
Did you get the 27F from Costco for $85? If so, how is the warranty?
Old 03-22-16, 01:39 PM
KC98LS
KC98LS's Avatar
Originally Posted by I'mStock
Width is different.
Appears to be exactly the same as my 24F. Any difference in minuscule.
Originally Posted by hyperopt
Awesome!
Sure did, Interstate brand with 3 year warranty, and additional pro rate.
Old 03-22-16, 02:40 PM
I'mStock
I'mStock's Avatar
Sorry about image quality but here's a 27F and a 24F right off our shelf...
Old 03-22-16, 06:20 PM
KC98LS
KC98LS's Avatar
That's strange, my 24 and 27 were almost identical in size. Would take a picture, but already gave old 24 back for core charge.
Maybe my 27 is a 24?
Old 03-22-16, 06:25 PM
KJG92
KJG92's Avatar
I used to work in a battery store when I was younger. The 24F in our 92 was not as wide as a 27 for sure. Check for a sticker on the side of the battery. You'll have a letter followed by a number. The letter will give the month and the number will be the last digit of the year. That will tell you the made date. The other sticker will tell you the group number.
Old 03-22-16, 07:39 PM
python
python's Avatar
no way a 24 is the same size!
Old 04-05-16, 11:51 AM
Schramm
Schramm's Avatar
As others have already showed, 24F is correct size for a 1998 LS400. I installed a 24F purchased from Lexus last year for my 1996 LS400. Not much different in price than direct from Interstate Battery. This battery size is sufficient for the coldest starts here in MN. Batteries only last about 6 years at most. The battery will last longer if you use the original plastic cover/insulator. It is designed to force intake air over the battery to keep it cool and prolong life.
Old 04-07-16, 07:17 AM
RugbyDad
RugbyDad's Avatar
Just get an optima and call it a day. Too tall? Cut holes in the hood. Duh...
Old 04-07-16, 03:48 PM
flaco1801
flaco1801's Avatar
Hard to believe people with 45 thousand cars are looking to save 100 for a battery that lasts 5 years....Just buy a fiat.......a quarter waiting on a nickel....
Old 04-09-16, 10:26 AM
oldskewel
oldskewel's Avatar
Are any of the Lexi on this 1st and 2nd gen list $45k cars? $25k? Do I hear a $5k? My '91 is awesome, but I doubt I could sell it for $5k.
And we're talking about a battery. Not quite as fungible as gasoline or oil, but close. Props to the OP for ignoring some advice, figuring it out, and letting us know - thanks.
BTW, in addition to optimizing price/warranty/size/specs/fit, one thing I try to do with batteries is to find ones that will fit interchangeably between my cars when possible. Many times electrical / battery-related problems are intermittent / weird / difficult to diagnose. I've found that just swapping batteries between cars to see if the problems stop or move is a good and very easy debugging step.
Quick Reply: 1998 LS400 24F VS 27F battery
