1996 vs 1999 parts compatibilty
Old 03-05-16, 05:31 AM
wbzautocus
wbzautocus's Avatar
Default 1996 vs 1999 parts compatibilty
Wanted to see if any of the parts are compatible from a 1999 ls400 to a 1996 ls400 I have a local junkyard that has a 1999 ls400 and its has a good gauge cluster, climate control, switches, etc for really cheap $$$ or if there is any hard to find parts I should try to get since the car is whole. I have other threads about gauge cluster and climate control issues so since my cluster will be going out for repair I wanted to have something to put in while other one is out and if my climate control is bad too I will send out so please lexus community don't chastise me about having 3 threads at once lol thanks for any helpful info
Old 03-05-16, 06:06 AM
Yamae
Yamae's Avatar
There are big design changes. Both the gauge cluster and the climate control are not compatible at all.
Old 03-05-16, 01:16 PM
sha4000
sha4000's Avatar
Most of the car was redesigned for the 98 model. Does it have a good front bumper? Ive been trying to locate one for a while. Most parts are on the west coast when i check car-parts.com
Old 03-05-16, 01:20 PM
Stereorob
Stereorob's Avatar
the shift **** and the seats are. that's about it..
Old 03-05-16, 06:52 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
and most of the suspension.
Old 03-05-16, 06:56 PM
wbzautocus
wbzautocus's Avatar
Thanks for info on compatibility info, as far as front bumper goes I didn't look real good but there was damage to headlights so bumper might be ok car is located in St Marys county Maryland
Old 03-06-16, 09:50 AM
CELSI0R
CELSI0R's Avatar
The wheels are also compatible, should you need them. I doubt that the front bumper will fit properly.
Old 03-06-16, 10:11 AM
wbzautocus
wbzautocus's Avatar
No I don't need bumper I was just posting the general area for any members that might need parts off car
Old 03-07-16, 12:10 AM
lextout
lextout's Avatar
All the body parts are compatible, check this out. 95 converted to look like a 98.
alot do this to there cars.
https://dubai.dubizzle.com/motors/us...Q%3D%3D&pos=15
Old 03-07-16, 09:24 AM
timmy0tool
timmy0tool's Avatar
sure they are compatible after being worked over at a body shop. i've seen in part numbers that even the doors vary between 95-97 and 98-00. anything can be worked to fit, but i believe the OP is asking for parts compatibility for direct bolt ins.
the climate control is another thing that is NOT a direct bolt in but can be reworked to function properly.
Old 03-07-16, 06:01 PM
Yamae
Yamae's Avatar
Are you sure?
Hope someone would not have serious problems believing your statement.
Old 03-09-16, 10:43 AM
timmy0tool
timmy0tool's Avatar
Originally Posted by Yamae
Are you sure?
are you telling me the climate control from a 98-00 will directly bolt onto a 95-97 car? maybe i was confused since the clocks are different from the model years and was mistaken to think it was related to the climate control. if so i type, corrected !
Old 03-09-16, 04:55 PM
Yamae
Yamae's Avatar
Timmy, reading below, you will be knowing why I worry about your statement.
https://www.clublexus.com/forums/ls-...t-smoking.html
Hope no more person will have the same smoking problem.
I know you are a kind person and you always try to help others. But sorry to say that I sometimes find some inaccuracy in your posts.
Old 03-09-16, 07:47 PM
timmy0tool
timmy0tool's Avatar
oops, this shows how much i know about our climate controls...i understand your concern and post to the best of my experiences and knowledge, and am always open for correction!
wbzautocus
03-09-16 12:58 PM
ls400love
11-09-11 08:11 PM
BlaineyB
SC- 1st Gen (1992-2000)
12-21-10 04:30 PM
dkinzer
11-20-08 10:22 AM
Mr.Pink86
05-04-06 07:26 AM
Quick Reply: 1996 vs 1999 parts compatibilty
