1UZ-FE valve adjustment - target values?
Old 02-26-16, 06:38 AM
Finn
Finn's Avatar
Default 1UZ-FE valve adjustment - target values?
Hello.
I have finally received correct tools from local Toyota (part number changed from one number containing both tools to two separate part numbers both containg one tool) and we are diving in tomorrow.
We did earlier a preliminary check on driver side bank but had to stop because I had received wrong tools from dealer.
The recommended valve clearences cold are:
Intake 0.15–0.25 mm (0.006–0.010 in.)
Exhaust 0.25–0.35 mm (0.010–0.014 in.)
I know that on #7 cylinder my intake valve clearance is around 0.40 mm and there are more that need adjustment.
My question is, what should I aim at: lower clearence value, higher clearance value or anywhere in between?
Typo corrected.
Old 02-26-16, 07:45 AM
Finn
Finn's Avatar
Both Lexus intake and exhaust shim thickness tables appear to use mean clearance values ie. 0.20 mm for intake and 0.30 mm for exhaust as grounds for the tables.
http://lextreme.com/shim/shim-intake.pdf
http://lextreme.com/shim/shim-exhaust.pdf
Old 02-26-16, 10:07 AM
dicer
dicer's Avatar
So number 7 is .0015 inches? That is pretty tight. How many miles on it?
Old 02-26-16, 11:47 PM
Finn
Finn's Avatar
Sorry for the typo. It is 0.40 mm on #7.
208000 km ie. about 130000 miles.
jameshan
06-07-19 09:48 PM
BULLIT
IS F (2008-2014)
13
02-22-13 08:14 PM
xxpezzxx
Performance & Maintenance
10-04-07 01:06 AM
Lex*Toy
05-21-06 02:41 PM
silkiechic
12-08-04 08:02 AM
Quick Reply: 1UZ-FE valve adjustment - target values?
