Starter solenoid 'clicking''
Old 02-13-16, 03:30 AM
fastegg
fastegg's Avatar
Default Starter solenoid 'clicking''
My VViT LS has 280,000km and the starter solenoid is starting to click-click... Is a solenoid kit suffice or would you replace the whole lot with a new or reco'd starter ?
Old 02-13-16, 05:00 AM
Stereorob
Stereorob's Avatar
oh boy........
Old 02-13-16, 06:18 AM
billydpowe
billydpowe's Avatar
two of my LS's have clicked, and both times we just put solenoid kits in and never had a problem.. my current driver got the kit in 2010 and is doing fine.. my nephew who works on Lexus said he has never had to replace a starter, just kits....
Attached Thumbnails Starter solenoid 'clicking''-100_1788.jpg   Starter solenoid 'clicking''-100_1789.jpg   Starter solenoid 'clicking''-100_1790.jpg   Starter solenoid 'clicking''-100_1791.jpg   Starter solenoid 'clicking''-100_1792.jpg
Starter solenoid 'clicking''-100_1793.jpg   Starter solenoid 'clicking''-100_1794.jpg   Starter solenoid 'clicking''-100_1795.jpg
Old 02-13-16, 06:50 AM
fixmiester
fixmiester's Avatar
Default I agree, but
Probably 95% of LS starter issues turn out to be just a relay or starter solenoid problem. A new solenoid is FAR cheaper than a new starter. BUT, it's such a hassle to get to the damned thing, that you should at least take a peek at the starter brushes, and see if there is plenty of life left, and that the armature looks okay. Otherwise, Murphy might bite you in the butt. Just sayin' .....
Old 02-13-16, 07:22 AM
Stereorob
Stereorob's Avatar
the dreaded starter issue is fitting for a prepare your anus ewok meme. its the one part LS400 drivers never want to have to see, or hold in there hand. 3 out of 4 Ls400s unfortunately I got to see the starters in them. lmao.
Old 02-13-16, 11:09 AM
oldskewel
oldskewel's Avatar
I don't have any specific knowledge on this item, but if it were my car, with that mileage and I were "in there" anyway, I would replace the brushes whether they need it or not.
Old 02-13-16, 02:46 PM
sha4000
sha4000's Avatar
Are you going to do the work yourself? I would try the solenoid kit if you are and make sure to test it on the bench and in the car before putting everything back together. When I did mine it tested good on the bench so I did not test it once back in the car until everything was bolted back up. Needless to say I had to go right back in there to put a new starter in the next day. It's not as daunting a task if you work on your own cars.
Old 02-13-16, 05:16 PM
fastegg
fastegg's Avatar
Default Starter soleniods
Well, its at 280,000 and the 2nd cam belt is due at 300,000 so I'm gunna do the starter and cam belt at the same time... Ive watched both jobs on youtube doco's and whilst its a bit daunting doing these 2 jobs one handed (left arm don't work) it looks quite achievable... I will pull the starter apart and inspect all parts and if everything is in ok shape I'll just do the solenoid kit.
... So over the next 20,000km I'll start getting a Gates timing belt kit, water pump etc, new fan belt and radiator hoses..... take a deep breath..... delv in......
*** By the way, Ive noticed on ebay there are varies starter motors available.. some say 1.2kw up to 2kw... Is this BS ?... are there some more powerful than others ?.... does it matter ?
Old 02-13-16, 09:19 PM
dicer
dicer's Avatar
The way I will do it, is, remove starter put in a reman one, keep the old one and rework it, I have one that makes a bad bearing noise, also it should be mandatory to change out the one way clutch to. So on a starter project and since its no easy task to arrive at that starter in hand situation, one should make sure before it goes back in that its in tip top condition, and not just the solenoid or the brushes, but the bearings and the clutch. Unless you wish to redo it all in a year or two.
Old 02-14-16, 04:15 AM
fastegg
fastegg's Avatar
Yes.. starting to feel I should put a recond one in just for piece of mind. Solenoid kit will probably do but since its such a job getting to it, I dont want to go back there for a very long time if ever.....
Old 02-14-16, 06:28 AM
billydpowe
billydpowe's Avatar
what do you mean a year or two, cant you read? mine is going on (6) six years, or is it you dont do math?
"]The way I will do it" is bunk. look at the photos... two bolts (on 98-2000) and starter is in your hand to inspect.
Old 02-14-16, 09:08 PM
dicer
dicer's Avatar
Well yeah he could do what you say and MAYBE it will go forever, and he could just fix the solenoid and in a month the brushes are all gone, or the clutch or the bearings go. And he could also take a few thousand to a casino and do that too and come out with enough to pay to have the whole car remanufactured.
Or I'm sure he would go with just the solenoid, if your nephew is going to volunteer to do all the work, for a cup of coffee and a smile, if he works for that sort of pay I got lots of projects for him.
Old 02-15-16, 12:38 AM
fastegg
fastegg's Avatar
Haha.. i pissed myself laughing at your post Mr dicer...very funny....
Old 02-16-16, 07:53 AM
billydpowe
billydpowe's Avatar
[QUOTE=fastegg;9366629]Haha.. i pissed myself laughing at your post Mr dicer...very funny.... [/Q
I almost did my self..
the real difference is if you are paying someone else to put it in or doing it yourself..
me?? Jon takes care of my LS.. I just cant do it anymore.
BNastee (12-05-19)
jerryparks
08-01-12 12:24 PM
2JZGTTELEX
SC- 1st Gen (1992-2000)
06-06-11 06:37 PM
cfuller74
07-21-08 08:04 AM
ynvme
07-09-06 12:45 PM
Quick Reply: Starter solenoid 'clicking''
