Power steering hose cracked on my 98 Celsior
Old 02-05-16, 08:09 AM
Yamae
Yamae's Avatar
Default Power steering hose cracked on my 98 Celsior
I just find this below. There are cracks as are indicated by yellow arrows.
This is a known issue as is shown here and I have been keeping an eye on this for the past a few years. But it has been OK up to just recently. We had very cold winter days for the last a couple of weeks and all of the sudden, those cracks started.
Now I need to replace the hose before it breaks.
Old 02-05-16, 10:11 AM
Legender
Legender's Avatar
In a pinch I subbed out some fuel line hose from O'Reillys for the reservoir to pump lines (supply/return) in my '98... it's obvious after 6 months that I need some true hydraulic lines as they're swelling up something awful. I think both the lines are 3/8ths or is one of them larger?
Old 02-05-16, 07:59 PM
djamps
djamps's Avatar
Mine broke when I changed the pump. Whole hose was hard as a rock.
Old 02-05-16, 11:51 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
This is the low pressure pump feed line. This can be replaced with any hose meant for higher temperatures like transmission cooler line and hydraulic (low pressure) hose.
I would NOT use a regular fuel line, it will work for a time but it isn't meant for the higher temperatures and will get hard again in a few years.
Old 02-09-16, 05:42 AM
Yamae
Yamae's Avatar
Yes, it was as hard as a rock indeed. I had a bit hard time to remove it due to the hardness.
Today, I replaced the hose after sucking the P/S oil as much as possible.
I used a genuine part 44348-50010 as is shown below. This was soft and quite easy to install.
Attached Thumbnails Power steering hose cracked on my 98 Celsior-hose-arraived.jpg   Power steering hose cracked on my 98 Celsior-sucking-ps-oil.jpg   Power steering hose cracked on my 98 Celsior-after-new-hose-installed.jpg
Old 02-09-16, 11:07 AM
dicer
dicer's Avatar
Old hard hose, just cut it to get it out.
Lexmus
RX - 1st Gen (1999-2003)
10-08-18 08:22 AM
Rob96ES300
05-11-16 05:25 PM
isaiah2011
08-14-11 09:56 AM
no1gsxr
01-11-10 10:29 PM
Blaizze
04-25-07 01:38 PM
Quick Reply: Power steering hose cracked on my 98 Celsior
