My first Post...93 ls500 and help needed inside
Old 01-10-16, 05:22 PM
93LS500
93LS500's Avatar
Default My first Post...93 ls500 and help needed inside
I have been a long time lurker/admirer here but never actually needed to make an account because most info was easy to find with a simple search, This however has me stumped. I have looked thru tons of wiring diagrams and harness layouts that i dont understand and cant find my answer so ill just ask...
what is going on under my steering wheel?
I had planned on replacing my cracked tan dash with a clean black dash then i saw this and figured i should address it before continuing. or maybe it doesn't matter at all but i have no idea
the car started and ran perfect before i unplugged all the stuff connected behind the dash and found these wires
so, what is the connector i circled in yellow? it was not plugged into anything . should it be?
inside the red circle why is my green wire cut and spliced into but running to nothing?
inside the blue circle the wire seems to be attached to a bolt (ground?) on the side of the column but the other end is not running to anything???
not sure if any of this is necessary considering i am stripping the whole car except this front dash area, just curious really
NOW ON TO THE OTHER SIDE...
behind the air bag i found this wire that appears to have a sensor or something cut off it
also not sure if this matters at all or even what it is or goes to?!?! it appears to be a red and a black wire in the same sleve but has nothing on the end
any help or even a direction to keep searching in would be great.
worse case scenario i put it all back together and have a cracked dash boo hoo
all comments suggestions are welcome and appreciated
Old 01-11-16, 03:07 AM
dicer
dicer's Avatar
First of all I hope you disconnected the battery before doing this.
All the funky wiring under the steering wheel looks like someone had installed some electrical device, and that was the power for it or a remote start or something like that. It is non Lexus and does not need to be there.
If you car doesn't start now its would be from doing this major electrical stuff with the battery still hooked up.
The other wire (glove box) you either need to find a junk yard car and look or check out the wire diagram. Someone has been playing with the electrics.
Old 01-11-16, 10:45 AM
RA40
Super Moderator
RA40's Avatar
My suggestion would be to pick up the electrical manual off that auction site or used book store. Then you'll have a reference for the wire colors. Definitely hacked but I couldn't guess what they are trying to tap into with the connections in the column. That's horn, lights, indicators, air bag and windshield wiper control.
Old 01-11-16, 12:32 PM
Kansas
Kansas's Avatar
I would bet that the extra wires were for an aftermarket cell phone system. These were extremely common during the 1990's and did not use any of the factory prewiring for the Lexus phone system option. I had a "President" cell phone system installed through the Lexus dealer in the LS400 I bought in 1990. It required two connections to the ignition - one constant 12V and one switched 12V on the accessory circuit. Its microphone wire ran up one of the windshield pillars.
If the owner of the 2000 LS400 I sold in 2014 ever disassembles its dashboard, console and trunk, he might be screaming "WTF are all these wires"? I installed a series of phone systems and electronic gadgets and usually did not remove the wires when I stopped using them or sold the car - just snipped the ends off so they didn't show.
By the way, the industry standard color for an aftermarket phone system audio system mute wire is "yellow".
Old 01-11-16, 12:54 PM
dicer
dicer's Avatar
Kansas I sure hope you still have that 90, if you did /do I would bet its the best Gen 1 there is.
Old 01-11-16, 08:43 PM
93LS500
93LS500's Avatar
THANKS for the responses,
So i got a better look today and realized the red and black wire behind the airbag was running to the little red light that sits on top the dash board (security light or something) i must have broke it loose when ripping the dash out. im guessing i should have removed the light first. not a problem. new dash has a new light.
also i cut out that green wire and ran a new jumper piece to the connector. although that connector doesn't connect to anything. might look into this in the future.
i didnt disconnect the battery but will start doing so in the future.
the car runs great and starts perfect even now that the dash is removed.
its actually a pretty fun drive with no interior
Old 01-11-16, 08:50 PM
93LS500
93LS500's Avatar
people here probably wanna see some wheels engine and low right??
well the car is in all primer right now. and full stripped
waiting for a cage welded diff and new interior
this is the worst it will ever look... radiused the fenders shaved the badges and antenna and set the coils as high as it can go on 19's to move it around easier also i painted the outer taillights red with the vht nightshades stuff.. you can see the fender metal just laying on the driveway i took 1" out of the front and 1.5" off the rear
oldskewel (02-06-18)
Old 01-13-16, 12:33 PM
sha4000
sha4000's Avatar
Why not a side shot?
Old 01-13-16, 06:22 PM
93LS500
93LS500's Avatar
Side shots look really bad right now ..car is like 4 different shades of primer on bent up 19" drift spares and missing sides skirts and stuff.. exhaust is all banged out of alignment ....its not good
I go pretty hard on this car
i actually took it out for a while again today to test the diff
and busted the intercooler off.
gonna do brake upgrade tomorrow if my lower ball joint arrived
hopefully have this sunroof deleted also
roll cage guy is holding me up
Old 01-13-16, 06:37 PM
93LS500
93LS500's Avatar
I found a side pic my friend took before i cut the fronts finished the rear and mounted my tires
Old 01-15-16, 08:45 AM
sha4000
sha4000's Avatar
Thanks and it still looks cool.
Old 01-15-16, 08:55 AM
djamps
djamps's Avatar
Looks like mad max lol
Old 01-15-16, 07:51 PM
93LS500
93LS500's Avatar
its pretty mad max right now...and it was so nice just a few weeks ago
the car only has about 50,000 original miles on it.
the new motor with all the flex fuel stuff has like 250 miles on it
I will have it finished before easter because thats the next drift event im going to.
a lot of work got done again tonight but still no cage and big brakes untill probably tomorrow
shortened the front arms so i didnt have to cut the enigine bay holes and got the toe adjusters in.
gonna do an alignment before bed then take it somewhere tomorrow to get an actual print out of my spec
maybe get it dyno tuned if i dont have to make an appointment, i know a place but not sure if its available tomorrow
Old 01-29-16, 06:43 PM
93LS500
93LS500's Avatar
I changed my coolant and now my air conditioning wont work
not sure how this is related, car had great really cold AC and now just blows hot air on all settings
not good i live in Arizona and it already gets hot in the mornings.
been searching but any advice would be appreciated
Old 01-30-16, 06:01 AM
sha4000
sha4000's Avatar
Changing the coolant would not affect the A/C. First thing to check is if the A/C clutch is operating when you turn the A/C on.It could be locked up.
Quick Reply: My first Post...93 ls500 and help needed inside
