Need help sourcing wiring harness plastic clamps
The original plastic wiring clamps on 99 LS400 engine wiring harness have seen better days....heat, time and mechanics have taken their toll. Thus am seeking new replacements.Lexus is challenged to locate the correct parts or provide P.N.s. At times their parts database is incorrect. After exhaustive research have not sourced correct parts Attached are images of the clamps, or whats left of them and where they reside...I notice several several are labeled "10" or "9" or "15" which is clamp I.D. Seeking part numbets and sourcing information
appreciated. Thanks
An image located online showing the wiring harness atop throttle body with two plastic clamps
An online image illustrating top view of clamp installed in bracket
Mine showing missing clamp attop throttle body.
Another clamp is for wire loom that runs parallel to valve cover and presses onto a bracket. The tan clamp is incorrect part reveivef from dealer.
Degraded plastic clamp on valve cover
One of the clamps with I.D. 10
appreciated. Thanks
toyotasrfu
09-03-07 07:23 AM
