Does anyone know...Cusco underbody brace?
Can anyone tell me if I can get Cusco or any JDM brand underbody brace or anything to strengthen the handling of my 2000 LS400? I just bought it a week ago. I don't want to turn it into a super racer. But a little mod will help.
Thanks a whole bunch!
Super Moderator
What are your goals and potential mods for the car? The car is sufficiently rigid as is and unless the HP goes way up and it will be driven hard as a sports sedan, the addition IMO is not going to be obvious. The squishy bushings and many other parts will be part of this equation for replacement.
Under body brace sounds like an okay idea as long as you can use existing holes and suspension mount points to attach it. And RA40 is right about all the soft rubber stuff, you need to attack it first. UCA's if they are all the same on all the LS series the stock ones are solid there are no rubbers, they may look like it but it is a steel ball socket at all 3 points. At least on the ones I have seen.
Super Moderator
Strut bar, upper and lower control arm, sway bar bushings, tranny, engine and differential mounts are usual suspects 100K+ miles. Have the ball joints and tie rod ends checked as well. I'm not driving our hard to seek out higher performance parts, the factory bushings are acceptable in maintaining the ride quality I like.
BrianV
12-17-02 01:47 AM
