2000 ls400 finding parts
Old 11-07-15, 05:18 PM
gregloren1
gregloren1's Avatar
Default 2000 ls400 finding parts
just bought 2000 ls400 with 175,000, love this car !! u get so much for 4,000 i still cant believe
propably my best $4000 invested ever...
car runs great, engine revs good, trans shifts smooth
i coudnt get any info on past maintenance on this car but i feel like it wasnt maintenance good enough, i want to keep my lexus happy running and feeling smooth
i started research on this forum and found very helpful post
https://www.clublexus.com/forums/ls-...ve-a-list.html
thanks for it !!
my only problem is i cant find all parts.
can you help me to find :
-engine coolant temp sensor (ects)
-strut bar bushings
-ecu capacitors
-spark plug wires and what spark plug, what you recommend
other than maintenance fixs a have problem with:
-sunroof not opening (i can hear engine working, looks like its blocked)
- steering wheel shakes during braking,brake pulsation (brake pads or Carrier Arm Bushings?)
- steering wheel shakes at high speeds 75mph+ (didnt check wheel alignment yet)
thank you for all help !!
Old 11-07-15, 07:46 PM
valex
valex's Avatar
Default Parts
Parts. com or check amazon, etc.
I would consider getting timing belt/ water pump job, would be more important in my opinion than suspension (Since there are no service records).
I don't think strut bar bushings are sold separately, only the whole arm with bushing $108.81 plus shipping each. Check other suspension parts for wear and repalce all worn parts - tie rods, lower ball joints, etc.
No spark plug wires on 2000LS, multiple discussions about plug choice.
Don't worry about about ECU capacitors, shouldn't be an issue on a 2000LS
Old 11-07-15, 08:17 PM
valex
valex's Avatar
www.amayama.com can save you a lot on OEM parts from Japan, there is a wait - around 2 weeks or so. I bought from them twice before. Prices about 1/2 of US prices, but you have to pay shipping, which is not outrageous. You have to know your part ## to search and to get quote.
Old 11-08-15, 03:13 AM
Losiracer2
Losiracer2's Avatar
I would definitely do the TB/WP job. I recently purchased a 97 LS with 253k, previous owner said the TB was done at 200k but doesn't know when. So going by that, it could've been 10 year or longer.
Fast forward to a month after buying it and 2k miles later my crankshaft seal sprung a big leak and coated the TB in oil, along with all the other idlers and tensioners. kinda put me in a hard spot since i was solely relying on this while fixing my swapped H22 Accord's valvestem seals and tranny.
So much for trusting the previous owner's maintenance schedule. He only had it for a year anyways so he didn't really do anything to it, other than obvious stuff such as brakes, radiator, hood struts, tint, and alternator.
Rock Auto has a OE quality Aisin Timing belt kit for 176, combine that w/ the 5% coupon promotion and you'll get the best kit with OE quality for the price. Nobody local or online could beat it. I also paired it up with VC gaskets, Tube seals, Cam and Crank seals and a new Thermostat to cover everything I could. Total spend was about 325. Rock auto also had a closeout on Fel-Pro VC gaskets at less than half of what they were selling for.
Old 11-09-15, 03:15 PM
gregloren1
gregloren1's Avatar
Hi !
all those things has been done or are set to be done
-timing belt
-water pump
-cleaning throttle body
-new air filter
-engine oil, tranny oil, coolant
-pvc velve
-positive battery connector
- new fuel cup gasket
- fuel filter
checked these websites too, i searched all google but cant find without part#
thanks for plug wires and ECU info
again .. part# thats why i asked you guys for help
Old 11-09-15, 03:19 PM
gregloren1
gregloren1's Avatar
basically now i just need part# for
and other than that i still have problem with:
if any one would recommend something else that should be done please let me know ! thanks
Old 11-09-15, 05:53 PM
valex
valex's Avatar
COOLANT TEMP SENSOR
Part Number
8942230030
There are part numbers on part.com
Shaking could be multiple things - wheel balancing, tie rods - I would start there, least expensive too...
Old 11-10-15, 08:37 AM
billydpowe
billydpowe's Avatar
SRB's are sold separately, have to press them out and in (do it right) tab down...
part numbers are available at Toyota do it your self web site
619miller
09-27-16 01:38 PM
Braincake
06-09-12 06:39 AM
waseem3000
26
03-28-11 03:27 PM
vinipuh79
05-12-06 06:23 PM
Slexus
Maintenance
06-13-03 01:27 PM
Quick Reply: 2000 ls400 finding parts
