Name this sound
Old 11-02-15, 07:48 AM
djamps
djamps's Avatar
Default Name this sound
'98 LS400, 200k miles. Done it since I bought ~195k miles it and it hasn't changed. Cold start there is no noise, only after warmed up. Car runs really strong either way. Audibly annoying more than anything else.
Audio of slow revs in my garage:
MP3 AUDIO CLIP
Old 11-02-15, 08:32 AM
alien1974
alien1974's Avatar
mine does this too 100k on the clock, i thought it could be the water pump, but as i am not losing water i am not worried
Old 11-02-15, 11:02 AM
1uzLexzeus
1uzLexzeus's Avatar
Well I'm no mechanic, but my first guess is that it might be the whirring of the fan or belts . We've had an 02 tundra that does in my family since 09 and its been runnin like a champ since. Although it is currently in the shop for (timing belts and water pump).
Old 11-02-15, 11:51 AM
RA40
Super Moderator
RA40's Avatar
What specific sound are we listening for? Seems pretty normal with the drive belt whirring, pulleys and fan spinning.
Old 11-02-15, 11:54 AM
djamps
djamps's Avatar
It's a whirring sound that follows the RPMs, especially noticeable between 1k and 1.5k RPM. Less at idle. Only makes the noise when the engine is warmed up. Seems pulley/bearing-ish to me. I figured a LS400/1UZ veteran might know what it is.
Old 11-02-15, 11:58 AM
djamps
djamps's Avatar
FYI I haven't ran without the drivebelt, but I did replace the belt and the PS pump (due to leaking) but the noise didn't change at all.
Old 11-02-15, 12:52 PM
KJG92
KJG92's Avatar
Transmission maybe?
Old 11-02-15, 09:04 PM
djamps
djamps's Avatar
So I'm really leaning towards the water pump. The intensity of the sound is practically identical to the temp gauge -- basically the amount of water flow. Getting the timing belt and water pump swapped soon, so we shall see.
Old 11-03-15, 08:06 AM
alien1974
alien1974's Avatar
mine does it on tick over
Old 11-03-15, 11:28 AM
cobalt91
cobalt91's Avatar
Maybe the fan clutch has gone bad?
Old 11-03-15, 12:01 PM
Nishy
Nishy's Avatar
no.... it's not whirring or ticking...
for real though, I have no idea
Old 11-03-15, 01:39 PM
djamps
djamps's Avatar
Thanks for the hints everyone, I'll slowly be tinkering with things over time -- main thing being the timing belt, pulleys and pump.
once I find the culprit I'll let you all know.
rns
Hybrid Technology
12-05-16 02:08 PM
dimapb
03-09-16 09:42 AM
xioix
Maintenance
12-23-11 10:29 PM
lexusben
11-28-10 07:11 PM
DCLexus
02-28-07 12:15 PM
Quick Reply: Name this sound
