Help how to wire 1UZ FE VVTI 97 WITH 89661-50450 STANDARD ECU
as noted above i have the engine and gearbox with standard ecu.
how do i wire this up as a basic bench test.
need wiring diagrams.
the loom is on the engine and gearbox with a few plugs to ecu.
I need pin out for 89661-50450 ECU
1. Need how to wire engine to start with fuse etc. ( i can then connect to my car's ignition)
2. then charging wiring setup.
3. get gears to change
i know it has built-in immo the bypass i will do later, fist need basic setup to run engine on its own and have gears work etc.
then can do connection to speedo etc. when i place engine into new car (discovery 3 tdv6)
please any assistance will do.
thanks
ed
Cape Town South africa.
thanks
ed
