K Sport UCF20 coilovers on UCF10?
Old 10-16-15, 10:28 AM
FastEddie7
FastEddie7's Avatar
Default K Sport UCF20 coilovers on UCF10?
Hey All - There's a set of used K Sport coilovers for a UCF20 on my local CL for a good price. I have a '94 UCF10. From what I understand from searching here, the UCF21 shocks will be longer. I want to lower the car a little, but not slammed like a lot of you guys do, so I'm wondering if they might work. I read some threads where people say they're running UCF20 Megans on UCF10s, and I see ads for some brands that say they fit 89 to 2000. So I'm guessing it all comes down to how long the K Sports actually are. Has anyone run them on a UCF10?
My car currently has the original shocks with 175,000 miles on them, so it needs something pretty badly.
Any insight is appreciated.
Old 10-16-15, 12:22 PM
I'mStock
I'mStock's Avatar
Search?
Old 10-16-15, 12:38 PM
Nishy
Nishy's Avatar
Im on Largus coils right now but from what I understand, ucf20 coils wont work for a ucf10. The 10 will for the 20 but not the other way around. The strut body is too long... maybe if you ran cut springs on your coilovers and had the strut all the way lowered it would work...
Old 10-16-15, 02:38 PM
FastEddie7
FastEddie7's Avatar
Originally Posted by I'mStock
Search?
Thanks for that. I did search, and described what I found in hopes that I wouldn't get this kind of crap. I hate forums like this.
Never mind.
Old 10-16-15, 05:16 PM
timmy0tool
timmy0tool's Avatar
don't let one answer ruin your forum experience! i'll try and help as best as i can.
to my understanding ksport coilovers are modelled after UCF10 cars so with that it should fit your UCF10 just fine after a few adjustments in length coming off a UCF20.
most aftermarket china made coilovers are based on UCF10s so most should fit 90-00 cars. tein is the only one i know that has a specific coilover for UCF20 chassis.
Old 10-16-15, 05:53 PM
FastEddie7
FastEddie7's Avatar
Thank you! I'd read that in a post about the Megans, but didn't know if it was true of other brands. Appreciate the help.
And yeah, sorry. I had a stressful day. I don't normally get to bent out of shape about that stuff. If I hadn't explained exactly what I found when I did search, it wouldn't have bugged me so much to see that as the first reply.
Old 10-16-15, 11:21 PM
RA40
Super Moderator
RA40's Avatar
+1 to what Timmy relayed.
Old 10-17-15, 03:05 PM
FastEddie7
FastEddie7's Avatar
Got them this morning. They look great. Seller said they only had a couple thousand miles on them, but who knows? About half what they cost new. So I'm happy. Can't wait to get them on the car!
Old 10-18-15, 03:50 PM
lev00221
lev00221's Avatar
FastEddie,
Please update us on how the coils workout. I would like to do something similar to my 1993 LS400.
Thanks,
Luis
Old 10-19-15, 03:36 PM
FastEddie7
FastEddie7's Avatar
Originally Posted by lev00221
FastEddie,
Thanks,
Luis
You bet. Seller didn't have spanners for them, so I ordered some. I have a million projects right now. New house, and the race car needs brakes, but hopefully I'll get up to the shop and get these on before too long.
Old 10-20-15, 02:42 PM
Kingsoup
Kingsoup's Avatar
I got a set of Megans for my 93 that were originally listed for 90-00, but they were not the right length and were not adjustable properly, the rears were too long. They had a very hard ride, and I ended up selling that car.
I have them another chance on my them for my 98 car, it was the same model number however they were no longer listed as being compatible for the 90-94 cars, and I suspect its because they are not compatible. They work night and day better on the newer car compared to the old.
It'll be interesting to see your results.
Old 10-20-15, 04:48 PM
timmy0tool
timmy0tool's Avatar
^ i do recall reading your experience about megans on your car kingsoup, which i do find odd! i suspect you might have installed them backwards, front to back and vice versa. rear coils are much longer than the fronts.
it will def be interested to see the OP's results.
Old 10-21-15, 07:51 AM
FastEddie7
FastEddie7's Avatar
That is interesting. Well, we'll know for sure, at least with regard to the K Sports as soon as I get some time. I'll be sure to post pics and observations. The K Sports are marked for front and rear, so at least I won't get that wrong. lol
I'm a little worried about the ride quality. I could do with something a bit stiffer than the worn out stock suspension. I'm sure it's better with good shocks. But I don't want to make it too hard. If there's a decent range of adjustment in the dampers, it would be cheap and easy to swap springs.
Old 10-21-15, 11:33 AM
timmy0tool
timmy0tool's Avatar
ride quality is subjective but try it out first and see if you like it as is. these cars are heavy and with the spring rates that come with basic coilovers, i personally enjoy the comfort they give out of the box! of course set the damping to a reasonable level, never at the softest or the hardest.
Old 10-22-15, 11:21 AM
Kingsoup
Kingsoup's Avatar
Hey Timmy! Oh I was very certain they were installed properly, you can't fit them in reverse as the rears as so much longer, the ride was still brutal on the softest setting, maybe I got a bad batch.
the new ones are much better, and have gotten significantly better as I've put more kms on the car, they keep getting softer and matched to the dampening better, (softest setting)
Still has Zero steering feel, but a big improvement over the stock suspension, just need to be matched to a softer sidewall tire.
jasonart
Suspension and Brakes
23
07-19-19 10:22 AM
Shervin350
08-16-15 07:33 PM
Chops@MVP
Club Lexus Vendor Marketplace
03-01-13 09:49 AM
harleydjce
06-08-12 02:06 PM
sc1jz
11-29-09 08:52 PM
Quick Reply: K Sport UCF20 coilovers on UCF10?
