TOYOBD1 and its wonders.
So I recently was pushed to buy this product after being bugged about it for a few months (not gonna mention any names but his initials are SIMON! lol)
But I must say. I am impressed. My car tells me everything. Connects to my phone. reads what I am doing at any point in time. And its just a small box and 4 wires and the directions come with. Here are some screenshots from it in action - if you end up wanting to talk to the guy who builds them in his house let me know, he isnt a member on here but he is a really cool dude.
https://drive.google.com/folderview?...Ws&usp=sharing
I just became aware of this device as I was searching for a connector that I could buy that would mate with the diagnostic port on our 1991 LS400.
I wonder why there are no follow ups?
I just ordered it and I hope it will somehow help me solve the years-long problem some (maybe many?) of us have with our early LS400: Becomes Erratically Unresponsive to Gas Pedal after thoroughly warmed over.
https://www.clublexus.com/forums/mai...em-solved.html
Don't want to hijack this thread but has anyone done this before me?
As I said I just discovered this but I think since the original post it looks like the inventor has made other versions. The one I ordered (TOYOCOM) has a real connector so it plugs right into the diagnostic port rather than having to poke individual pins into holes. $85.89 US including postage from Canada.
I was in the process of BUILDING a replacement for the Fuel Pump Resistor to try since that part is no longer available (except used) it seems.
I wouldn't worry about the availability issue on a fuel pump resistor. There are many other methods. Of course you have to be careful for the heat generated by the alternative one. I have many 0.1 ohm/10W resistors and using 7 of them in series makes it possible to work as a original one. Another method is to use 2 of H3 bulbs or equivalents in parallel. Bulbs show smaller resistance when used at smaller current and just 2 is fine for this application.
The TDCL connector wasn't fully used to its fullest potential even by Toyota techs at the dealer despite the fact the older Diagnostics Tester(a Toyota-labeled Vetronix MasterTech 3100) and the 1st gen Techstream was capable of interfacing with it and reading off the serial data stream. Not too many mainstream Toyotas had it - only Lexus did. It was like GM's ALDL in a way - but the aftermarket back then supported Detroit more.
http://toyota.kgbconsulting.ca/wiki/...rial_Interface
