Removing center console
Old 04-23-12, 08:32 PM
johnnyg66
johnnyg66's Avatar
Originally Posted by Kansas
I doubt if you will have to remove more than the wood console panel, ashtray and center vents above the radio to do that - five minutes if you've done it before ... 10 minutes if you haven't.
Yeah i have done all that before. I just want to get good access thru the center console to run some wires to the back. For rear camera and gps antenna.
Think when i take out the arm rest compartment like you do to take out cup holders i will be fine.
Old 04-26-12, 04:43 AM
ditch2
ditch2's Avatar
helpful diagrams, thanks
Old 06-03-14, 05:36 AM
Chinny83
Chinny83's Avatar
Can anyone tell me how to get the actual arm rest off the rest of the console. I have the console removed the air ducting out the rear controls removed i just cant get the hinges and the base of the hinges to seperate from the console without trying to pull it out and crack the plastic console frame???
Old 06-03-14, 06:07 AM
billydpowe
billydpowe's Avatar
you need to identify what you are working on in your post, since the models change...
Old 06-03-14, 06:11 AM
Chinny83
Chinny83's Avatar
Are yes.. My bad.. It is a 1992 LS400
AlaskanLS
02-13-17 11:33 PM
Ali SC4
SC- 1st Gen (1992-2000)
03-01-10 07:47 PM
Jasbmo
07-03-07 10:15 PM
DJ SprinklesNJO
RX - 1st Gen (1999-2003)
02-18-02 04:35 PM
Quick Reply: Removing center console
