1UZ swap looking for new dif setup
Old 09-26-15, 11:45 AM
Zer0xKewl
Zer0xKewl's Avatar
Talking 1UZ swap looking for new dif setup
Hey guys, ive just finished my project of swapping a 1st gen 1uzfe into an 87 supra. looking to find out some info on what I would need in regards to the differential to get a better gear ratio for the car. right now I sit at about 4000 rpm @ 80mph, no bueno haha. any info is greatly appreciated, thanks!
running with oem w58 and original drivetrain btw.
Old 09-27-15, 04:06 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
I'm guessing you had an original 7m-ge car with the w58? If so you should have a 4.30:1 rear end, which is why your gearing is so high.
an '89-92 Supra Turbo Manual (R154) car should have a 3.73 clutch pack LSD diff as standard (in the US) that should bolt in and drop your rear end ratio to make it taller and drop cruising RPM by about 5-600 at speed.
The guys at supraforums and supramania (for more mk3 centered info) are probably a better source than here.
Brendon
Performance & Maintenance
29
01-13-16 01:20 PM
drastiq619
13
01-23-15 11:58 AM
cheez
SC- 1st Gen (1992-2000)
10-29-10 11:34 AM
sclover222
07-08-09 06:13 AM
silversc3
08-13-02 10:11 AM
Quick Reply: 1UZ swap looking for new dif setup
