'92 LS400 -motor has missing problem
Old 09-17-15, 11:09 AM
jerryparks
jerryparks's Avatar
Default '92 LS400 -motor has missing problem
Any ideas what I need to check to solve a missing problem? I've changed the wires and plugs. Replaced one knock sensor and installed a new fuel filter.. Also checked the exhaust system for
blockages. Help!
Old 09-17-15, 03:47 PM
cobalt91
cobalt91's Avatar
Caps and rotors can cause a miss fire. Is it showing any diagnostic codes?
Old 09-17-15, 05:51 PM
Bprakash
Bprakash's Avatar
I still have this problem after changing filter, caps and rotors, plugs and wires and ignition coils. No codes. Next I will work on injectors.
Old 09-18-15, 09:50 AM
timmy0tool
timmy0tool's Avatar
does it misfire at idle or under acceleration? have you addressed your ECU capacitors yet?
Old 09-18-15, 11:23 AM
cobalt91
cobalt91's Avatar
Don't throw parts at it. Find the problem and fix it. Does it change if the coils are disconnected? Can you hear any vacuum leaks? Take your time and check every thing before you buy parts.
Old 09-18-15, 01:35 PM
jerryparks
jerryparks's Avatar
It idles OK, miss only occurs under excleration. My car repairman thinks it could be the timing belt. I put some high test gas in it today and it did not help.
Old 09-18-15, 06:17 PM
Bprakash
Bprakash's Avatar
I miss at idle and at high speed. I will fix an injector next week and hope to solve this problem.
Old 09-18-15, 11:09 PM
dicer
dicer's Avatar
Its funny how everyone likes to just start tossing parts at a problem. If you don't know how to properly trouble shoot, it maybe cheaper to find someone that does. The very first thing to do is look at a service manual. Either go to a dealer and ask to see it. Or go online to the Toyota site and down load it. Follow the trouble shooting chart in it. A constant miss does not always have to be caused by electrical or fuel supply. There are mechanical conditions that can cause it.
And wow a knock sensor? I hope you changed, overhauled, got new, did something with the starter when you did that.
Old 09-19-15, 10:03 AM
jerryparks
jerryparks's Avatar
Yeh, replaced starter about six months ago. Its possible I should have replaced the other knock sensor as well. The one I replaced had some broken parts on it. The other one seemed OK, so I left ot alone.
Old 09-19-15, 08:16 PM
brybo86
brybo86's Avatar
You can get to the knock sensor in about an hour
The starter is what takes another 6 hrs
Old 09-22-15, 08:09 PM
python
python's Avatar
absolutely not true...cant believe some of the stuff im reading. listen to dicer here and stop with the crap advice and throwing parts at these cars gets expensive.
Old 09-23-15, 09:23 AM
sha4000
sha4000's Avatar
What did he say that was not true? He did not give advice on how to diagnose or fix the current problem. he just said it takes about and hour to change a knock sensor but the starter takes much longer.
Old 09-23-15, 12:00 PM
python
python's Avatar
i was under the impression the intake had to be removed...upon further research,some have done it without doing so..my bad
Old 09-23-15, 12:18 PM
dicer
dicer's Avatar
It looks close to impossible to do with out taking all the plenum and intake out of the way. Its easier to remove the whole intake than to deal with removing fuel rails and all that as I'm sure that fuel rails and throttle body etc has to be removed to get to them. Then there is releasing the connectors on them and getting a tool in there, if it can be done I bet its very tight.
Old 09-24-15, 05:41 PM
sha4000
sha4000's Avatar
The intake does need to be removed but that's the easy part to a starter job IMO.
Quick Reply: '92 LS400 -motor has missing problem
