H & R Springs question
Old 09-10-15, 07:04 AM
saleenssc
saleenssc's Avatar
Default H & R Springs question
Car: 98 LS400
Anyone using these exact springs? They say a 1" Front and rear drop. How accurate is this? I dont want to go any lower than 1" in the Front & rear. Anyone have pics of these on a 98-00 LS400.
H&R 95-00 Lexus LS400 Sport Lowering Springs 52426
http://www.ebay.com/itm/321840042336?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
thanks
Old 09-10-15, 07:28 AM
Stroock639
Stroock639's Avatar
i honestly think it might be slightly more than 1 inch after everything settles but i've had no issues
Old 09-10-15, 07:32 AM
saleenssc
saleenssc's Avatar
thanks for the response. Car looks good. Did you install them yourself ? if so how difficult is it to do? How much should i pay to have someone install these for me.
Old 09-10-15, 07:41 AM
Stroock639
Stroock639's Avatar
thanks. nah i had them installed, it's no more difficult than installing any other type of spring. the shocks need to be removed but that's standard
Old 09-10-15, 08:05 AM
saleenssc
saleenssc's Avatar
what spacer thickness are you running for your Trak+ ??? 5mm, 15mm, 20mm
thanks
Old 09-10-15, 08:14 AM
Stroock639
Stroock639's Avatar
10mm in front 20mm in back. one "issue" (more just a slight annoyance) is that after lowering it the back wheels got a bit more negative camber than i'd like so i may be looking for a camber bolt. with the 245 wheels, 20 mm spacers and 1" drop there's like less than an inch of wheel clearance
Old 09-10-15, 09:24 AM
9000revs
9000revs's Avatar
Overall, the H&R seems to lower about 1.25".
Old 09-10-15, 01:42 PM
Daspyda
Daspyda's Avatar
You DID get an alignment after the suspension change, right?
Old 09-10-15, 02:37 PM
Stroock639
Stroock639's Avatar
yeah i did don't worry lol
Old 09-10-15, 02:40 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
the factory camber adjustment should be able to compensate for the 1" drop.
Camber bolts don't work properly on multi-link rear suspensions.
Old 09-12-15, 04:28 PM
Stroock639
Stroock639's Avatar
so the LS does have a factory camber adjustment? how much range is there, i'm only looking for a few degrees of positive camber to make it match the front, and there also seems to be less grip on the inside wheel in turns. does adjusting the camber affect ride height? if anything i'm hoping it'll raise the back up ever so slightly, otherwise i might have to go to a slightly smaller spacer to avoid that lip on the inside of the back fender that the front doesn't have for some reason
RickyDavis
20
03-22-13 09:00 PM
williamb82
03-26-10 06:00 PM
Quick Reply: H & R Springs question
