98 LS400 broken airbox/vacuum leaks
So I got this ucf20 a couple months ago, and it was neglected unfortunately. This particular problem is due to the previous owner breaking both vacuum nipples off of the airbox. I need advice on how to fix the exisiting airbox or sourcing a different one.
So right now the valve cover breather is to atmosphere as well as the other hose which I think goes to the charcoal canister?
Pics of broken nipples:
It doesn't run horribly.....it idles low when in drive though
Super Moderator
Easy to fix for less than $7. As PD mentions in the thread various nylon/plastic tube fittings are available to adapt for what is necessary.
https://www.clublexus.com/forums/ls-...e-fitting.html
Your warning is about two weeks late. I broke mine off leaning over the engine changing out the starter. First I super-glued it back on then JB welded it by forming a dam around it with duct tape. It's held for the last two weeks. If it breaks, the radiator removal isn't that hard on this car, just took around 15 minutes to take it out to clean it.
I JB welded the nipple at first and it didn't hold long term so then I drilled out the hole and screwed in a brass fitting with JB weld and it held up with no problem. I ended up buying a new Denso radiator from rockauto for $69 because the top fitting that holds the upper radiator hose was falling apart and the hose slipped off on 2 different occasions almost leaving me stranded. Lucky I ride around with a jug of coolant and distilled water.
ls400beave
10-31-11 03:34 PM
