LS400 Tranny Solenoid Cleaner?
Old 08-31-15, 06:37 PM
tyncobb
tyncobb's Avatar
Default LS400 Tranny Solenoid Cleaner?
I just pulled 4 transmission solenoids from a salvaged 1994 LS400 & am planning to replace my worn solenoids with these
Can anyone recommend a safe cleaner to use on these solenoids? I saw a thread where someone used CRC MAF cleaner, but am wondering if I need to use a cleaner that will not affect the electric connectivity of these parts? OR DO I EVEN NEED TO WORRY ABOUT THAT ISSUE?
Any suggestions would be greatly appreciated; soloing this job this weekend, thanks.
Old 09-01-15, 11:18 AM
700bones
700bones's Avatar
I use CRC PF Precision Cleaner. This is made and recommended by CRC specifically for sensitive electronic parts. I use it on SMT electronic assemblies. It's specifically rated as safe for relays, coils, motors, and so on. Those parts mentioned use the same self-bonding enamel magnet wire found in solenoids. This is what I used to clean flux of my ECU's PCB (do not use isopropyl alcohol for that!)
Old 09-03-15, 10:35 AM
tyncobb
tyncobb's Avatar
Default CRC "PF" Precision Clearner Recommendation
THANKS FOR THE RECOMMENDATION 700Bones!
I just purchased a can of this cleaner (at $45.00!) and based on your information and the cost alone, I think this must be the best cleaner on the market particularly for my application.
Plan on replacing the now cleansed solenoids this week and will post the results once tested. Thanks again for the recommendation and advice. I really needed the help as I am not an electronics guy at all.
Joeyc850
09-17-14 08:15 AM
MOswagga
12-16-10 08:28 AM
SC400SAIF
SC- 1st Gen (1992-2000)
09-18-10 02:08 PM
LS400_96
02-27-09 12:41 AM
Quick Reply: LS400 Tranny Solenoid Cleaner?
