Weird electrical problem 95 ucf20 HELP!
Guys, I have a problem. I was at the drive thru at Arby's when out of the blue my AC control panel, outside temp gauge and clock all went out. Car is still running fine but lost my AC and half of the electronics in the dash. Weird problem I've never seen before. I asked the techs here and they asked me how fat my wallet was, so that's obviously a bad sign. They said it could possibly be a body ECUS among other things. Def need some opinions. Could it just be a fuse? Worst case scenario?
Check for ODB codes, then move on:
Check charging system, then battery, then grab a multimeter and check for leakages on each fuse.
If no issues are reliably reproduced, ask more experienced users than me.
https://techinfo.toyota.com/techInfo....toyota.com%2F
If you don't have manuals and schematics this is your place. For these cars electrical you will need the correct information. Its not an easy deal with out it.
BilluAwan
12-07-08 09:20 PM
Greydog
02-05-05 04:05 PM
