Rear wheel bearing replacement with knuckle on car
Old 08-12-15, 11:55 AM
brybo86
brybo86's Avatar
Default Rear wheel bearing replacement with knuckle on car
1995 LS400
planning rear wheel bearing replacements and wondering if this can be done without disconnect all of the suspension parts
I would like to do the following steps similar to here
http://mkiv.com/techarticles/rear_wh...ing/index.html
remove wheel
remove hub nut
remove axle from differential side
remove caliper
remove disc
remove parking brake shoes
now at this point can i use a big hammer/or puller to push the axle in towards the differential where it is already disconnected?
also can I then use the puller to remove the hub?
remove the circlips
use a wheel bearing tool like this to push out old bearing and install a new one
then reassemble?
is this possible? or does the entire knuckle need to come off?
Old 08-12-15, 12:02 PM
dicer
dicer's Avatar
I guess we will find out. Should work, and where did you get the kit?
Old 08-12-15, 12:06 PM
brybo86
brybo86's Avatar
I havent bought it yet but you can rent/borrow from autozone/oreillys or buy from harbor freight
maybe boils down to how much force the tool can apply compared to a hydraulic press?
Old 08-12-15, 03:02 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
the knuckle has to at least be unbolted for the axle to come out, the axle is not collapsible much at all so you can't just "push" it out with the knuckle still in place.
The wheel bearing races have to be pressed in and done so perfectly concentric to the hole they are going in, they cannot be canted. This will be quite difficult to do with the knuckle still on the car.
Old 08-12-15, 04:49 PM
brybo86
brybo86's Avatar
How much horizontal play will the axle have once unbolted from the differential?
I thought there was just a single sealed bearing in each knuckle? not separate races and bearings?
Old 08-12-15, 04:52 PM
PureDrifter
BahHumBug
VERY little horizontal play. Almost negligible but likely a couple mm.
The bearing race is the metal component the *****/needles sit in/on. The Outer race is the metal ring portion of the bearing that is in contact with the knuckle.
Old 05-01-16, 08:28 PM
valex
valex's Avatar
Changed lots of things in the rear on my 99LS, brought knuckles to a mechanic to press in bearings. Assembled everything today and took it for a test drive. Left rear metal -to- metal noise, I first thought it was the big dust cover around rotor on knuckle, but closer inspection revealed the noise is coming from axle rubbing on something inside knuckle.
Do you think the dust deflector wasn't pressed all the way in?
Seems like whe the axle rotates, there is one spot where it rubs on something.
Old 05-02-16, 12:41 PM
PureDrifter
BahHumBug
sounds like it wasn't reassembled properly.
Old 05-05-16, 08:31 PM
valex
valex's Avatar
Turned out to be a bent backing plate (shield behind rotor). And that was the first place I looked, I don't know how I missed it!!!
All looks good, did alignment, summer wheels on and rady for my roadtrip CO- CA!
rkw77080
03-21-24 07:30 AM
Gtpspeed02
08-05-17 12:29 PM
QCisf
IS F (2008-2014)
07-27-14 06:43 PM
pourSc
Performance & Maintenance
03-20-12 04:26 PM
Quick Reply: Rear wheel bearing replacement with knuckle on car
