95 LS400 starting issue
Hey guys I'm new here, my 95 ls has been randomly not starting, anywhere from 3 try's, to about 30 minutes of trying to start it. I turn the key, and nothing happens, not even a clicking noise, just complete silence. If any of you have encountered this problem or have any info, it's greatly appreciated, thanks for the help
Connections are clean, and I have not tested my battery yet. my power steering pump reservoir was leaking bad for about 2-3 months, but that has been fixed for about a month now, just some extra info
Did you check the NSS attached to the AT (Neutral Safety Switch)? When it's failed, there's no clicking sound at all.
Try starting at N instead of P. If not successful, try shifting back to P then N repeatedly.
Super Moderator
Starter is going to need a rebuild or replacement with the given that the battery and wiring is in good working order. Starter replacement is a pretty common item past 150K miles. Shop around, of if you DIY, we have threads here. Get it fixed ASAP, the moment it clicks you are on borrowed time is running out before you'll need a tow.
https://www.clublexus.com/forums/ls-...d-starter.html
