Transmission - front pump
Old 05-17-15, 08:13 AM
Dave_G
Dave_G's Avatar
Default Transmission - front pump
My 1998 LS 400 with 213,000 miles has a front pump in the transmission that is going bad and it started making noise when coming to a stop and while stopped. Has anyone had experience with fixing this problem and what did you do?
Old 05-17-15, 09:11 AM
Banshee365
Banshee365's Avatar
That noise can be caused by the pump being starved of fluid. Pull your pan and check the fluid strainer.
Old 05-17-15, 12:54 PM
sha4000
sha4000's Avatar
Never seen anything on the board about the front pump.
Old 05-17-15, 08:38 PM
dicer
dicer's Avatar
And it is the only pump. In the old days there was a rear pump too. It was very nice as you could push start your automatic transmission car, I did it a few times, sure miss that, just nothing like progress and modern engineering.
It could be low fluid level, plugged screen, and anything that allows it to suck in air. Not saying it can't be bad but those transmissions will go 300,000 miles and maybe more so look for the simple things first.
Maher331
03-09-18 01:16 AM
MyGS3
GS - 1st Gen (1993-1997)
14
03-04-14 09:00 PM
Viking65
RX - 1st Gen (1999-2003)
04-30-13 12:11 AM
benjanet
02-02-12 04:10 PM
Farino81
Performance & Maintenance
01-25-12 03:52 PM
Quick Reply: Transmission - front pump
