Timing mark help
Old 03-27-15, 03:45 PM
sancarlos1
sancarlos1's Avatar
Default Timing mark help
I am installing a new timing belt as my 93 ls400. It jumped time. the tutorials indicate that the crankshaft belt drive gear has a dot that is at the 6 o'clock position when number 1 cylinder is at top dead center, mine has no "dot" all mine has is a "U" at 12 o'clock and two threaded holes about 10 and 4, I am pretty sure it is at TDC as the rotor is pointing at number one cylinder and the crank pulley timing mark was on zero when i removed the crank pulley. Has anyone experienced this type of drive gear?
Old 03-27-15, 07:01 PM
sancarlos1
sancarlos1's Avatar
Default Don't have the "dot"
my 93 does not have any markings except the U which is at 12 o'clock
Old 03-27-15, 09:04 PM
sha4000
sha4000's Avatar
A pic would be nice.
Old 03-31-15, 01:54 PM
aomdedude1
aomdedude1's Avatar
Look harder, there is a notch on the crankshaft gear. If the U is facing 12 o'clock, the notch I am speaking of should line up perfect with the nipple on the oil pump casing. The nipple and notch are circled in red in the picture below. If they are lined up, you are at TDC.
Old 03-31-15, 02:17 PM
aomdedude1
aomdedude1's Avatar
And here is what the CAM gears should look like.
Left Cam:
Right Cam:
And excerpts from the service manual:
Old 04-01-15, 04:11 PM
timmy0tool
timmy0tool's Avatar
^ awesome pics! need to add to timing belt guide!
Old 04-07-15, 04:47 PM
aomdedude1
aomdedude1's Avatar
Thanks man, I have pics of pretty much everything on this car... Timing belt, rear wheel bearings, ECU...lol
Feel free to use them for whatever!~
Old 12-17-17, 07:33 PM
lateralnw
lateralnw's Avatar
Default Pict
Left Cam:
Right Cam:
What happened to the pictures?
I could really do with then atm.
Fitted new timing belt and cam/crank seals on a sc400 1uzfe same as LS400. Won't start and distributor rotor pointing down at tdc or at 12 at tdc not sure which is compression stroke at the moment.
Pictures anyone?
Thanks.
Old 12-17-17, 08:22 PM
Banshee365
Banshee365's Avatar
Pictures anyone?
Thanks.
Imageshack nuked linking a while back so all photos linked to there flag out now.
Look over my timing belt tutorial and see if it helps. Remove your crank sprocket and clean thoroughly with a tooth brush on the front face. The mark is small and get's filled with crud over time. https://www.clublexus.com/forums/ls-...-belt-diy.html
lateralnw (12-18-17)
Old 12-18-17, 02:53 AM
lateralnw
lateralnw's Avatar
Thanks Banshee for the quick reply.
Managed to start the car but it won't idle so I'm guessing I got the cams in the right spot!
Will check out your link.
re links to photos I use https://imgur.com/ and they haven't started charging etc (yet) but I believe you can also attach directly to Club Lexus which is where I thought these photo are stored given there was no picture holder in the post.
draider
10-26-22 08:38 PM
KhmerPride
Performance & Maintenance
15
02-10-21 05:14 PM
SenecaRex
12-31-15 03:55 PM
gripmatic
05-05-10 06:29 AM
okis_ebay
10-19-07 07:22 PM
Quick Reply: Timing mark help
