A650E gearbox mods
A650E gearbox mods
Ive read that there is a 3 setting valve inside the sump of the gearbox the can be turned with a screwdriver that shortens shift time. Is this true ?
BahHumBug
yes, there's a tutorial in the GS forum. It does shorten shift time but only slightly (only a valvebody will make a big difference) but it does reduce slipping during shifts, resulting in firmer shifts. I've had my line pressure increased for a few years with no detriment. read up: https://www.clublexus.com/forums/per...ting-dial.html
That said, this isn't nearly as good a solution as a full performance valvebody.
this sounds very intriguing
A650e
I just had my mechanic take the pan off and adjust the three step valve screw. We clicked it up no probs. 2 hours & $250 later including a $42 gasket. If it did make a difference I can't notice it. I supplied my own 100% syn Nulon fluid.
Anyway, personally if anyone's thinking of doing this mod, spend you $$ on something else.
Anyway... does anyone know anything about these shift kits ?.. I just typed A650E into ebay and up came these...
I rang them and the guy was very informative. It replaces a couple of 'worn' sleeves and valves and restores the trans to OEM pressures. As my car is 270,000km up, the shifts are very smooth and 'lazy' ... probably alot less firm than when new, the result of less line pressures. This kit replaces the worn sleeves and valves in the valve body and he almost guaranteed that a trans that had my mileage, it would considerably improve the shifting firmness both up and down gears.
Interesting...... I'm thinking of getting some ramps and doing it myself... its just that I'm not looking forward to working on the transmission whilst lying on my back.... GRRRRR...
keep in mind these are not high performance transmissions and do shift "lazy". the trans should shift smooth as butter, after all it's a luxury car! i know you are trying to squeeze performance but you can only get so far from the original intent.
it's a good idea to rebuild due to high miles, but i have not seen anyone rebuild the valve body using the kit you have.
$42 for a gasket seems crazy, the fel pro TOS 18748 i bought was under $10, even shipped from amazon
BahHumBug
No, completely not needed. These cars came with smooth transmissions that work by slipping between shifts, hence slow but smooth and not fast and firm. No amount of "correction back to stock" will fix that.
If you want faster, harder shifts then you need to look at a fully built performance valvebody from the likes of IPT or Level10. Both make valvebody setups for the A650e.
A650e
Ive got no problem getting a shift kit... but I'm looking at at least $200+++ for freight there and back and the time the car is off the road. I guess I would probably have to get the valve body out myself as I'd imagine it would be several weeks getting it back.
Anyway, I had to try that 3 step screw mod... If it made a difference I can't tell... $250 !!!!!!!!.... I had to try......
KC95SC400
Performance & Maintenance
282
10-06-17 09:50 AM
ICONYQ
06-10-12 12:09 AM
