Need Color info please
I was hoping someone can tell me what color my door trim is where the door handle bezel is by the pictures, I need to replace the bezel but not sure which color to order. Also my car is mystic Gold but what is the lower half color called and the color number of it? Thanks all for any help.
Not sure on the Paint code, but that bezel around the door handle with the memory seat buttons is the "oak" trim, with a part # of 69278-50050-E0..
Unfortunately that color is out of production, I have the same color on my 95, and all you can order new now is black.
Sewell has all the colors below listed for a 99 but not sure if it would be considered light tan or dark agate? I've ruled out the black and dark blue gray colors obviously.
69278B 6927850050C0
BEZEL, FRONT DOOR INSIDE HANDLE, (LH - LEFT / DRIVER SIDE) (W/ LEXUS MEMORY SYSTEM), IVORY (LIGHT TAN), TRIM0# 01 In Stock $28.82 $25.17 $17.58
69278B 6927850050B0
FRONT DOOR INSIDE HANDLE BEZEL (LH - LEFT / DRIVER SIDE) (MEMORY ADJUST SYSTEM), DARK BLUE GRAY, TRIM1# 01 Ships 24-48 hrs $25.34 $22.12 $15.46
69278B 6927850050C0
FRONT DOOR INSIDE HANDLE BEZEL (LH - LEFT / DRIVER SIDE) (MEMORY ADJUST SYSTEM), BLACK, TRIM2# 01 In Stock $28.82 $25.17 $17.58
69278B 6927850050G0
FRONT DOOR INSIDE HANDLE BEZEL (LH - LEFT / DRIVER SIDE) (MEMORY ADJUST SYSTEM), DARK AGATE, TRIM6# 01 Ships 24-48 hrs $28.18 $24.61 $17.19
69278B 6927850050C0
69278B 6927850050B0
69278B 6927850050C0
69278B 6927850050G0
Looks like the same color as mine. My trim code is LF03. Ivory interior. Not sure why they don't list the darker accent color, but when I ordered my mats, which should match the trim, they were Ivory/taupe.
69278B 6927850050C0
It looks like you just order by what color your main interior is and they send the corresponding trim piece. My interior is Ivory so the one above should get me the correct bezel color. If I'm wrong I'm only out $17.58
So can anybody tell me what color the lower half of my car is called or the color code for it. I know the top is Mystic Gold 4P7 but I need to order touch up for the lower section and I have searched everywhere and cant find anything about the bottom half.
hello, the driver side bezel with memory is 69278-50050-E1 yours is SANDAL WOOD, TRIM0
the right side would be 69277-50060-E1
my 1998 LS400 have the same interior colors as yours and I ordered one last year.
