Is there any problem switching oil?
Old 10-30-14, 06:36 PM
RobertE
RobertE's Avatar
Default Is there any problem switching oil?
About to change the oil on the 99 LS400 I just got and wondering if there is any problem switching a car that has been run on Dino oil for 134K miles to Synthetic oil. Just want to make sure it wont cause any problems. Thanks for any responses.
Old 10-31-14, 03:05 AM
cgawelko
cgawelko's Avatar
Well. If you have an oil leak or a oil burning problem, expect it to accelerate a bit with full syn. Smoother, more efficient with less build up and it will have less restriction leaking where the dino oil did. But the LS400 should have always been on Synthetic, never on that Dino garbage. Most guys will say go to Toyota and get the 5w-30 Toyota oil - thats what Toyota says is the ONLY weight to run in a 99 LS400. You should have been using full syn from day one since you have VVT-i but thats in the past now.
Old 10-31-14, 11:15 AM
timmy0tool
timmy0tool's Avatar
there is no problem changing from conventional to synthetic. the car never came with syn from the factory, and can only benefit from the switch.
now going the other way, syn to conventional, is a controversial topic.
if you have time, read here about the basics of oil.
Motor Oil 101
Old 11-01-14, 04:28 PM
YoshiMan
YoshiMan's Avatar
Engines don't care what's in them... Unless its turkey gravy or something.... then they do tend to care!
Old 11-02-14, 06:44 AM
billydpowe
billydpowe's Avatar
love it Yoshi.... Engines don't care what's in them
and I am getting hungry for some Turkey Gravy and Dressing.. yummmm
Old 11-02-14, 07:57 PM
YoshiMan
YoshiMan's Avatar
Ha ha! that made me laugh!
I guess I should clarify that every time I have a motor oil discussion, SOMEONE always says: "once you go to synthetic oil, you have to keep using it and cannot switch back to regular" And I have to ask where this wife's tale came from??
It's not like the engine is going to stand up and say "uhm, excuse me, this is not that fancy synthetic stuff you used last time, I'm going on strike"
wayman28
02-26-16 07:48 AM
gandro
Maintenance
01-06-10 08:44 PM
EthanV
11-29-08 02:55 AM
BostonBill
18
04-30-06 05:00 PM
sktn77a
RX - 1st Gen (1999-2003)
08-19-05 10:23 AM
Quick Reply: Is there any problem switching oil?
