using a tablet in the centre console
Old 10-22-14, 03:16 PM
simrx3
simrx3's Avatar
Default using a tablet in the centre console
sorry if a repost, i did search
so ive read somewhere that there are people using a tablet (say around 10") and removing the HVAC controller and the stereo. then mounting it where the HVAC controls and stereo sits.
it controls the HVAC and stereo. plus do extra stuff like show gauges etc..
who has done this and what programs and wiring systems are needed?
as my HVAC unit is dieing
cheers
Old 10-22-14, 03:49 PM
simrx3
simrx3's Avatar
found this -
no mention of it running the HVAC system though
Old 10-22-14, 04:09 PM
Mugen_1
Mugen_1's Avatar
^^ Interesting. I've debated removing my ashtray and slightly expanding the surround it sits in to make a custom setup for my Note 3 since I use it for navigation all the time. If I come across a spare wood trim piece from a junkyard I might try that out and see. Obviously not a full tablet mount, but the Note 3 is no small screen.
Old 10-22-14, 04:14 PM
Sc0pe
Sc0pe's Avatar
Personally, I'm contemplating installing a Windows tablet to use as a standalone head unit. Gonna be a little while before I start on it, though.
Old 10-22-14, 05:06 PM
simrx3
simrx3's Avatar
wouldnt think it wouldbe too hard...
just need the software to control a I\O module and put the input\outputs of the car to it..
Old 10-22-14, 06:45 PM
simrx3
simrx3's Avatar
have measured it up and a 10" tablet will fit sweet
might look into some i/o modules that operate via blue tooth.. so cabling into the tablet wont be too bad..
Old 10-22-14, 07:17 PM
Yamae
Yamae's Avatar
In order to perform it, the most time consuming job would be to analyze the interface signals and to make equivalents. Before your HVAC fails you'd better to analyze those since Toyota does not open the detail.
Signal names are known and it would be not impossible for those who are skilled to replace the HVAC and the audio unit to a tablet.
Old 10-22-14, 08:10 PM
simrx3
simrx3's Avatar
thanks Yamae
will have to get onto it..
was thinking of running it so you touch the screen and radio/hvac interface.. then after you change what you need to have it revert to a couple of gauges which will run off the haltech elite i installing soon
Old 10-22-14, 09:17 PM
Sc0pe
Sc0pe's Avatar
As far as the audio goes, I'm just removing all of the OEM equipment, and replacing it with aftermarket equipment. Then I will use a USB to Optical cable to connect to a Digital Sound Processor, and then from there, to the amplifiers that will control the new speakers.
Old 10-22-14, 09:24 PM
simrx3
simrx3's Avatar
cool..
just did a quick look at it.. 10" looks good. alot neater
Attached Thumbnails using a tablet in the centre console-imag3099.jpg   using a tablet in the centre console-imag3100.jpg
Old 10-23-14, 03:03 AM
RugbyDad
RugbyDad's Avatar
If you ever get this all up and running, I would love to have a full install rundown (necessary parts, etc).
It's nice to let someone else do all the legwork and trial & error..
Old 10-23-14, 04:45 AM
simrx3
simrx3's Avatar
No probs..
Just keep an eye out on my build thread..
Old 12-20-14, 10:27 AM
bornking
bornking's Avatar
so has anyone got the AC controls to work on an ipad?
Old 12-20-14, 01:43 PM
simrx3
simrx3's Avatar
Hi mate,
I can't see why not.
You just need an I/O module to mimic the outputs of the hvac system...
kobedb8
11-11-17 10:06 AM
zander654
03-18-11 08:50 AM
flamekat
13
08-10-06 11:21 PM
sk8er251cc
30
01-08-04 09:13 PM
abefromansausag
SC- 1st Gen (1992-2000)
10-30-01 10:57 PM
Quick Reply: using a tablet in the centre console
