Head rest question
Old 09-30-14, 12:29 PM
dicer
dicer's Avatar
Default Head rest question
On a 92, head rest has one position, that is extended. Looked in the holes on the driverside seat and the one to the left has what looks like a small reduced diameter flange at the bottom of the hole that will not let it go down. Any info on this?
Old 09-30-14, 01:40 PM
timmy0tool
timmy0tool's Avatar
what are you trying to do? get the headrest to go down into the seat? remove the headrest?
Old 10-01-14, 01:25 AM
dicer
dicer's Avatar
Yes it will not go down. Basically its just one position, there is like a reduced diameter hole that stops it as mentioned above.
Old 10-01-14, 08:37 AM
sha4000
sha4000's Avatar
Is there a tab at the top of the seat that you have to push in to release the headrest?
Old 10-01-14, 09:50 AM
dicer
dicer's Avatar
Yeah I have to push both them, need 3 hands pretty much. That all works. Its still that restriction in the LH hole on driver seat anyway didn't look at pass seat. It won't go down either. I really don't get it. And yes both the latches that hook the shafts work if they didn't I couldn't get the whole head rest off.
Old 10-01-14, 03:03 PM
sha4000
sha4000's Avatar
Are both poles on the headrest the same size? Maybe try to switch the headrests around btw seats.
Old 10-02-14, 12:01 AM
dicer
dicer's Avatar
I didn't check that. I will when I can.
Old 10-04-14, 08:39 AM
billydpowe
billydpowe's Avatar
my headrest adjust with a button on the side of the seat..... dont all of them??
it is the small up and down button beside of the seat adjuster..
Old 10-04-14, 09:30 AM
sha4000
sha4000's Avatar
The early models did not have that option Billy.
Old 10-04-14, 09:39 AM
billydpowe
billydpowe's Avatar
thanks sha, I forget a lot (over 80)
Old 10-10-14, 03:17 PM
dicer
dicer's Avatar
Okay these seats must be out of an older one???? The rear seat has the correct button on the side to lower the head rests. The front seats have just the 2 plastic grommet looking things you have to push down both at same time to disengage the head rest, also the posts only have one notch, I looked at another 92 it had correct button and post had extra notches. So what seats or seat backs are these?
Old 10-10-14, 07:36 PM
sha4000
sha4000's Avatar
Post up some clear pics.
Old 10-11-14, 01:23 AM
dicer
dicer's Avatar
No working camera at this time, that's another project to do.
Old 10-11-14, 01:37 PM
billydpowe
billydpowe's Avatar
you dont even have a cell phone?? they take photos..
Old 10-11-14, 02:24 PM
dicer
dicer's Avatar
Yes they did. I didn't expect it, just a bit more studying, just haven't spent much time around em. Step son drives a 90 I just fix it when it breaks.
Cell phone is 12 years old no camera its a phone. Problem solved. 1992's do have electric powered head rest as an option, its also in the shop manual
Quick Reply: Head rest question
