Looking for alinement specs
Old 09-29-14, 01:45 PM
dicer
dicer's Avatar
Default Looking for alinement specs
For 1990 - 92 ls400.
Toe, camber, caster etc. front and back.
Old 10-03-14, 11:16 PM
dicer
dicer's Avatar
There is zero information about this on the net.
Old 10-04-14, 07:32 AM
billydpowe
billydpowe's Avatar
a search turned up this... you do one:
look: https://www.clublexus.com/forums/ls4...tire-wear.html
http://www.aligncraft.com/cars/lexus.html
http://us.lexusownersclub.com/forums...ear-irregular/
http://www.vipstylecars.com/forums/a....php/f-55.html you might find something here
Old 10-04-14, 08:00 AM
billydpowe
billydpowe's Avatar
my manual is for 98-2000 but sa5 & sa9 cover alignments
File Type: pdf
File Type: pdf
Old 10-04-14, 08:05 AM
python
python's Avatar
if ur googling the word "alinement"...well that could be the problem
Old 10-04-14, 08:22 AM
billydpowe
billydpowe's Avatar
I was going to let him find that out for himself.....
they may use phonetics in Washington, however: onomatopoeia doesn't include real words and phonetic transcription uses some extra symbols (not from the alphabet)...
cheers!!
Old 10-06-14, 02:36 AM
dicer
dicer's Avatar
Don't have time now. But thanks to all. Yeah a spelling dummy here sometimes.
Old 10-06-14, 10:32 AM
Gene01
Gene01's Avatar
The spelling he used was common in WWII-era military manuals (e. g "RF alinement"). I think (can someone confirm?) that the Brits use it also.
Old 10-06-14, 10:34 AM
dicer
dicer's Avatar
At least I can spell BRAKES and also know how to take lots of BREAKS at work.
Old 10-11-14, 09:50 PM
dicer
dicer's Avatar
Here they are if anyone needs this info. For 1992 Non air suspension.
Camber 0 degrees, plus minus 45 minutes (Left right error 30 minutes or less)
Caster 9 degrees 10 minutes, plus minus 45 minutes (LR error 30 minutes or less)
Inclination 8 degrees 45 minutes, plus minus 45 minutes
Toe in (total) 0.2 degrees, plus minus 0.2 degrees, (2mm plus minus 2mm)
Wheel angle inside wheel 39 degrees 20 minutes (plus 1 degree minus 2 degrees)
outside wheel 32 degrees 40 minutes
The above is for front.
Rear
Total,Toe in .2 degrees, plus minus .2 degrees (2mm, plus minus, 2mm)
I don't know why most everything was in degrees and minutes and toein was in decimal degrees.
To help show what it means.
http://www.carparts.com/alignment.htm
dRo15
Wheels and Tires Classifieds
06-21-14 12:27 AM
Galvez
05-01-14 08:52 PM
John9689
03-10-13 08:52 PM
GFerg
01-13-10 12:41 PM
stevechod
Suspension
09-11-09 08:09 AM
Quick Reply: Looking for alinement specs
