98 LS loud bang on speedbump in front after lowering!
Old 08-05-14, 11:12 PM
davincity
davincity's Avatar
Default 98 LS loud bang on speedbump in front after lowering!
So I put the tanabee springs 2.0 drop in front and 1.5 in the back and now whenever I go over a bump at low speed or high speed I hear a loud bang up front as if the tire is hitting the frame or something I'm not sure. I also replaced the struts. Please help! 225k miles runs like a dream and always dealer maintained.
Old 08-06-14, 12:16 AM
kevvo
kevvo's Avatar
If you look underneath the car is any part of it lower than the height of where the rim meets the tyre?
Old 08-06-14, 10:15 AM
timmy0tool
timmy0tool's Avatar
did you trim your bump stops when you installed the springs? could also be your upper a-arm hitting the inner wheel well but that is not likely since a 2" drop is very small.
also check if all the parts are nice and secure, swaybar, strut mount, etc.
Old 08-06-14, 04:33 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
a-arm hitting the shock tower for $500 alex.
Old 08-06-14, 08:18 PM
Caniac14
Caniac14's Avatar
I can confidently say that it is the UCA(a-arm) hitting. My driving height is about 2-3" drop and I hit every time I enter my driveway unless I literally creep in.
My suggestion would be to take them at an angle if you aren't going to scrape, and be slow about it.
Old 08-06-14, 10:56 PM
RA40
Super Moderator
RA40's Avatar
Mine is at 2.5" drop up front and I've not hit the UCA. Possible on a hard compression but if the bump stop was cut at the first tapered neck, I don't see how it can contact in the wheel well. Mine is good for 2.25" of clear suspension travel. If the bump stops were not cut, that that leaves about 1/2-1" of suspension travel before it bottoms out. If it has an RCA installed, then yes it will be closer and possibly contact the wheel well. Easy to tell because the UCA will have left a mark.
My thought is that the caster bar bushings are very unhappy in this new position. The other big noise could be the engine and tranny bouncing around. Uncut bump stop, speed bump, engine and tranny get bounced up then back down. Check the engine and tranny mount.
IreneIS350
09-06-17 08:04 AM
beamerrx7
03-18-17 04:28 PM
xinkid
04-15-12 12:42 PM
das277
Suspension and Brakes
12-30-09 05:29 AM
crolex
05-03-07 11:53 AM
Quick Reply: 98 LS loud bang on speedbump in front after lowering!
