LS 400 instrument cluster
Old 07-14-14, 09:52 PM
Xica
Xica's Avatar
Default LS 400 instrument cluster
I have a 1990 LS400 and the instrument cluster is going wacky. First off the speedometer is reading 15 mph slower than actual speed. Also the indicator light that says there is a burned out tail light is on but all of the tail light bulbs are working. When I am driving the car and step on the brake pedal the brakes grab slightly and the "R" lights up on the shift light column and the dash light turns off. I am guessing I need to replace the instrument gauge cluster but would appreciate any input if anyone else has experienced this.
Old 07-15-14, 05:15 AM
usoff89
usoff89's Avatar
Have you tried searching the forum? I see this is your first post..... You might want to post this in the actual LS400 thread and not the "Build" thread.
Old 07-15-14, 10:37 AM
TaninAuto
Sponsor
TaninAuto's Avatar
We can fix all of these problems or sell you a good working cluster.
The gear shift assembly on the transmission triggers the gear lights so I would start there with that problem. The speedometer problem is the cluster.
__________________
TANIN AUTO ELECTRONIX
262-456-4147
contact@taninauto.com
www.taninautoelectronix.com
growrx300
RX - 1st Gen (1999-2003)
04-13-15 09:06 AM
iridebmx
SC- 1st Gen (1992-2000)
02-25-11 07:34 PM
LexLS
49
01-12-11 10:41 AM
sc4002soar
05-16-09 07:50 PM
Quick Reply: LS 400 instrument cluster
