A/C blower motor and no power
Old 07-12-14, 09:22 PM
sancarlos1
sancarlos1's Avatar
Default A/C blower motor and no power
I just purchased a 93 LS100 with 110,000 miles for $690.00 at an auction. It ran but had no power and the A/C blower motor would not operate at any selected speed. Used this and other sites to try and diagnose the problems. No power was easy to fix the left bank coil wire was frayed causing engine to run on four cyls. replaced the coil wire and woke it up runs great. A/C was more difficult to fix, A/c was working just not blowing, checked the fuse in drivers footwell, was OK, dropped the right side dash checked the blower motor by disconnecting the two wires that power the motor and jumping from a 12v source blower motor worked OK, replaced the relay attached to the blower housing and the resistor with junk yard spares, still did not work. I checked every fuse and found no bad ones. owners manual states that the circuit breakers in the drivers foot well should be reset if the a/c doesn't work so i reset them, no help. I replaced the heater relay under the hood and that fixed it. Should have checked the easy stuff first, problem is i read a couple of posts that stated relays almost never fail. I guess I am the exception makes the rule.
LexXxtacy
08-13-19 02:27 PM
FcknJ
09-16-17 06:24 PM
JZSARISTO
Florida Lexus Club
13
02-11-12 09:44 AM
superfreak
Maintenance
10-12-05 07:36 AM
Quick Reply: A/C blower motor and no power
