Difference between 1ls and 2ls transmission mount
Old 01-23-14, 10:29 AM
Twista4004
Twista4004's Avatar
Question Difference between 1ls and 2ls transmission mount
So I ordered the 95-00 transmission mount and saved some $ (90-94 was $20+ more). They looked the same in the pic.
It bolted up fine but I did have to use a hydraulic jack to "squish" the mount just enough so that the bolts for the cross member would reach the chassis (not sure of long term effects if bolt may creep or if it'll be perfect.)
Old mount came out in two pieces (as always). Ride is slightly smoother. Pretty sure engine mounts would cure the rest.
I think the difference between the 1LS and 2LS mounts is probably the thickness of the actual rubber. I noticed that the old one when put next to new one was noticeably less thick. Don't know if that's age or what. Sorry I never thought of taking a photo of the two of them for comparison at the time.
Just thought I'd put this out there in case anyone ever thought of ordering the second generation transmission mount to install on their first generation LS. So far it works fine.
Old 01-23-14, 11:53 AM
LScowboyLS
LScowboyLS's Avatar
interesting!
Old 01-23-14, 11:54 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
Sounds like the rubber is under more compression than it's designed to be. I would imagine that would have a negative effect on durability.
Old 01-23-14, 12:46 PM
RA40
Super Moderator
RA40's Avatar
+1 with PD.
Stop by the dealer and have him pull both parts. Snap a photo for us so that we can see. Basically the height differences on the pads.
Old 01-23-14, 03:00 PM
billydpowe
billydpowe's Avatar
great idea RA
Old 01-23-14, 03:36 PM
Twista4004
Twista4004's Avatar
First thing I thought of when I did it actually but I figure it's a scientific endeavor for the betterment of the LS400 community so I would try it out. lol
I'm going to also experiment with some new struts this weekend as well. I've gotten a lot of flack for even THINKING to use the STAGG SHS struts but I hear excellent reviews and only came across one negative one that that was PRE-install. No word after install
Old 01-23-14, 03:40 PM
Twista4004
Twista4004's Avatar
BTW, me "squishing" it with the jack was only because I needed maybe 1/4 inch more clearance and I was awkward position. I'm pretty sure if the car was higher and I was laying on my back, I could have gotten the clearance pushing by hand.
Anyway, if it breaks, I buy a new one of the proper year and install. Experiment results noted.
Old 01-23-14, 03:42 PM
Twista4004
Twista4004's Avatar
Originally Posted by RA40
+1 with PD.
Not really any Lex dealer close but I'll see what I can muster on my day off. You guys should make the calls to the service department to see if they have them in stock for me since I'll be going there on my own time, dime and your curiosity.
Old 08-25-14, 07:45 AM
Twista4004
Twista4004's Avatar
In case anyone cares, the trans mount is still holding great.
Old 08-25-14, 02:00 PM
PureDrifter
BahHumBug
the correct factory part lasts for ~80,000miles and ~10 years.
7 months is a bit soon.
tradosauru
01-05-22 03:56 AM
greens14
Performance & Maintenance
06-17-13 02:02 PM
Eds98LS
03-30-13 08:27 PM
djpolak
05-08-09 09:24 PM
Quick Reply: Difference between 1ls and 2ls transmission mount
