Ticking sound - is this normal....
Old 07-01-14, 08:17 AM
mhora
mhora's Avatar
Default Ticking sound - is this normal....
So my LS had a fairly loud tick coming from the top end of the engine... valve train im guessing... my question is this normal.. and is tjere anyway to adjust then too get rid of it?
Old 07-01-14, 02:33 PM
sha4000
sha4000's Avatar
The tick is normal but should not be that loud.
Old 07-01-14, 04:07 PM
lextout
lextout's Avatar
Sorry but this is not normal at all for a ls not even on cold start
Old 07-01-14, 04:10 PM
randal
randal's Avatar
Some ticking is 'normal' as they age. There is no easy adjustment. You have to shim the clearance.
At a minimum, I would pull the valve cover and just have a look at the cams. Might be be some build up of "crud". Sometimes a thicker oil in summer will help with the ticking especially on high mileage engines.
What year is your LS and how many miles?
Old 07-01-14, 06:38 PM
sha4000
sha4000's Avatar
I used to hear that tick when i ran 10w30 briefly and it disappeared when I switched back to 5w. That was many miles ago though. Since I did the cam seals I can hear it again but that's only if I have the hood open.
jaishanker
07-31-18 11:10 AM
2JZ4lyfe
Performance & Maintenance
10-08-14 09:18 PM
gtknoles
03-12-14 02:31 PM
deanbrown
11-08-09 07:46 PM
jfascia
10-30-01 08:06 PM
Quick Reply: Ticking sound - is this normal....
