Help identifying OEM bolt part number - Club Lexus Forums
Thread Tools Search this Thread
Old 06-29-14, 10:03 AM   #1
DeZyn243
Default Help identifying OEM bolt part number
I was driving home and went over a hump in the road and when I passed over it I heard something come loose and bang the under carriage of my car. When I got under it to identify the problem I noticed that this bolt in the attached pics came off. can anyone help me identify the bolt part number so I can replace it?
Help identifying OEM bolt part number-92lexls400.jpg   Help identifying OEM bolt part number-92lexls400-3.jpg
DeZyn243 is offline   Reply With Quote
Old 06-29-14, 10:40 AM   #2
sha4000
sha4000's Avatar
That's the front crossmember the bolt goes into and I would not drive the car until you replace it. What year is the vehicle?
http://www.lexussouthatlantaparts.co...rimLevel=19107
sha4000 is offline   Reply With Quote
Old 06-29-14, 10:54 AM   #3
DeZyn243
It is a 92
Old 06-29-14, 11:12 AM   #4
sha4000
sha4000's Avatar
Same concept, it's a bolt for the front cross member.
Old 06-29-14, 11:56 AM   #5
DeZyn243
Right!
But I'm trying to figure out what the OEM part number for the bolt is though.
The dealers are closed out here so I am trying to find it online but they keep asking for the part number of the bolt and I don't have it
Old 06-29-14, 01:37 PM   #6
sha4000
sha4000's Avatar
Look on the diagram in the link i posted.
Old 06-29-14, 02:11 PM   #7
DeZyn243
I appreciate it.
I've seen this diagram, but it looks as if it is only showing the bolts for the side of the crossmember.
There are two bolts on the side, 1 in the front and 1 in the rear.
I need the bolt for the rear side.
In the diagram I only located the 2 for the side.
I emailed the Lexus dealer, maybe they can shed some insight into that bolt on the rear.
I can't find it anywhere
I'm only finding the crossmember for sale n I just need the bolt.
Old 06-29-14, 03:56 PM   #8
billydpowe
billydpowe's Avatar
why not take the other bolt out and go to the hardware store and get one??
billydpowe is offline   Reply With Quote
Old 06-29-14, 04:27 PM   #9
DeZyn243
That is actually my next step tomorrow if the dealer is charging an arm n a leg for the bolt.
I will pay a few dollars more if I can do less work.
I'm assuming that if I have both bolts off of the backside then it is going to knock my alignment off.
Good idea tho
Old 06-29-14, 09:03 PM   #10
billydpowe
billydpowe's Avatar
I didnt mean to drive that car..... everybody has a friend.
Old 06-29-14, 09:24 PM   #11
DeZyn243
I wouldn't be driving the car with both bolts off. I can't even drive it now with the one bolt missing. I was saying that I assume if I remove both bolts there would be no support to keep my alignment in tact, forcing me to realign it. Where as if I just replace the one bolt that is missing I might be able to slide by without having to do so.
Old 06-30-14, 03:33 AM   #12
PureDrifter
BahHumBug
PureDrifter's Avatar
that's not a crossmember bolt, it's a rack mounting bolt. Still not drivable without it.
'92 part numbers:
90119-12173 for the bolts
90179-12113 for the nuts
PureDrifter is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
Help Identifying Hose from Airbox rollin73 RX - 1st Gen (1999-2003) 8 08-10-14 08:54 PM
Need help identifying oil leak... carlos IS - 2nd Gen (2006-2013) 11 01-24-11 03:58 PM
Need help identifying part number for a GX470 "Shift Lock Cover" motoguci GX - 1st Gen (2004-2009) 6 07-20-10 06:41 AM
How can you identify the AFS option on the headlight? SC400_408 IS - 2nd Gen (2006-2013) 17 03-01-07 01:23 AM
HELP!!! need help to identify a screw Grimpy SC- 1st Gen (1992-2000) 22 04-24-03 07:44 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright © 2000-2016 Internet Brands, Inc. All Rights Reserved
