Extremely rough idle and lots of mechanical noises - resetting computer solved it
Old 06-12-14, 10:16 AM
Finn
Finn's Avatar
Default Extremely rough idle and lots of mechanical noises - resetting computer solved it
Cheers all!
OK, here's what happened:
Last Saturday I pushed my -91 out from the garage - pushed did not start - to make room to work on my Harley. After few hours I was done and I started the engine and drove said 15 feet back in. Engine was running slightly faster idle when I shut the engine off.
Today I went in the garage to take LS out. I started it and it did not start as it usually starts with ease but...well...differently. I noticed immediately that the idle was very, very rough and there seemed, well, that's what it felt, to be all sorts of mechanical noises. I shut the engine off almost instantly.
After a while I started it again and it was slightly better but not what it should be. I listened to the engine idling and reversed the car out and shut it off.
Something in the back of my head told me to reset the computer and I pulled battery cable off and let it sit for a while. I then put the cable back on and started the car. Most of the roughness and such were away and I went for a ride. Now after 20 miles or so computer seems to have re-learned and 1UZ-FE purrs again smoothly. With a tick-tick but smooth nevertheless.
QUESTIONS:
What exactly happened on Saturday when I shut the engine off in fast idle? Was it in some sort of warm-up phase that messed up the computer?
If I had not reset the computer today would it have learned and cleared the situation by itself?
Old 06-12-14, 02:57 PM
timmy0tool
Forum Moderator
timmy0tool's Avatar
have you had your ECU capacitors changed?
i don't like starting a car just to move it a few feet then shutting it back off especially when cold. i like to keep the car running for at least 5 minutes for the oil and fluids to circulate. this is where the most wear and tear happens on your engine.
Old 06-12-14, 05:56 PM
sha4000
sha4000's Avatar
Probably did not give the alternator enough time to recharge the battery correctly. I'm with timmy on this one, I also let the car run until it's at least warmed up before shutting it down.
Old 06-12-14, 08:21 PM
Finn
Finn's Avatar
I don't like starting the car for 15 feet either but that was a must - now I know better ie. either let it idle longer or take it for a spin.
We do not seem to have ECU capacitor problem on this side of the pond. Never heard anyone mentioning that here. Mine - apart from this hickup - works like a dream.
LVPUNK
03-17-24 04:38 AM
MattLS400
190
03-18-21 03:28 PM
lovetheIS
11-16-16 12:45 PM
piamill
CT 200h Model (2011-2017)
01-19-13 08:54 PM
v8pwr
12
03-05-02 01:54 PM
Quick Reply: Extremely rough idle and lots of mechanical noises - resetting computer solved it
