Quick Question. 1uz broken motor mount
Old 06-08-14, 02:12 PM
lexbubba90
lexbubba90's Avatar
Question Quick Question. 1uz broken motor mount
can I use a passenger side motor mount on the driver side of the car? vice versa?
Old 06-08-14, 02:16 PM
lexbubba90
lexbubba90's Avatar
I have 2 1uz's but both driver mounts are broken and both passenger mounts look fairly new with no signs of stress..so if it is possible I have the parts to swap over
Old 06-08-14, 04:13 PM
sha4000
sha4000's Avatar
I believe you can since they have the same part number.
Old 06-09-14, 04:35 PM
oldskewel
oldskewel's Avatar
Yes, 90-94 at least, left and right mounts are the same part.
But it can be a lot of work to remove and replace, and maybe the passenger side ones are not as new as they might look before you remove them.
I replaced both on my '91 with OE parts. I don't recall significantly different wear on left vs. right. Dramatic improvement in smoothness after that job (and did the AT mount as well at the same time).
Old 06-11-14, 08:36 PM
lexbubba90
lexbubba90's Avatar
thanks for the info!
Arcturus
03-20-21 09:12 AM
matto
SC- 1st Gen (1992-2000)
04-09-14 07:37 PM
mcfancy
11-24-13 10:42 AM
Hectorm
12-06-08 08:43 PM
Invisibleman
07-22-03 05:49 AM
Quick Reply: Quick Question. 1uz broken motor mount
