differential/transmission
Old 06-01-14, 06:38 PM
abelvee
abelvee's Avatar
Default differential/transmission
I have a 90 LS ....So, i blew my diff ..my car wasnt going anywhere. Swapped in another one I had picked from a junkyard (92 LS) when I put in Drive it doesn't move ..but when I put in Low (first) it moves ...I have to take off in first then move to drive ...tranny problem ?....help
Old 06-01-14, 08:21 PM
sha4000
sha4000's Avatar
Was it doing this before the swap?
Old 06-01-14, 08:47 PM
abelvee
abelvee's Avatar
No it wasn't
Old 06-02-14, 01:38 AM
cobalt91
cobalt91's Avatar
Any warning lights?
Old 06-02-14, 02:01 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
check fluid level and all wiring.
Old 06-02-14, 03:51 PM
abelvee
abelvee's Avatar
No warning lights ..and what wiring ?
Old 06-02-14, 04:15 PM
timmy0tool
timmy0tool's Avatar
fluid level in the trans. how do you know you didn't blow your transmission too?
Old 06-02-14, 04:25 PM
abelvee
abelvee's Avatar
Well It works ..I just have to drop in first manually or it won't go ..then I drive off then put it in drive
Old 06-02-14, 06:03 PM
YoshiMan
YoshiMan's Avatar
My dad had a Jeep Cherokee as his take home car about 10 years ago, and it did the exact same thing once.... would not respond if you put it in drive, but if you started from "L", got some speed, and then switched it to drive, it would work fine.... I know those have an Aisin Transmission too, and if i remember, it was a relatively simple fix...
Old 06-02-14, 08:53 PM
abelvee
abelvee's Avatar
What was it ?
triage400
07-22-18 07:53 PM
ArtyJay242
10-07-14 05:14 AM
gsedan400
Performance
01-03-11 09:57 AM
Leines
RX - 1st Gen (1999-2003)
11-28-10 07:21 PM
mandolays
09-08-10 04:01 AM
Quick Reply: differential/transmission
