Definite guide to upgrading 1st gen LS400 front brakes to 2nd gen
Old 05-28-14, 06:19 PM
peterls
peterls's Avatar
Default Definite guide to upgrading 1st gen LS400 front brakes to 2nd gen
The info on brake upgrade is hard to find as bits and pieces are all over the place, so I will try to put all the stuff right here.
First of all, 1990-1992 LS400 had one pot brakes, which as we all know simply suck.
1992-1994 had two pots, which was a little better.
Second generation LS400, 1995-2000 finally got it right: four pots and tons of braking power.
First the list of things you will need to do the upgrade:
1. New set of 16" wheels (1990-1992 LS400 comes with 15" wheels and those are not big enough for larger calipers from the 2nd generation LS400). Notice you need 16" wheels from an LS400, not just ANY 16" wheels - most others would not be large enough on the inside to fit the larger calipers. So, either stick with Lexus LS400 16" wheels, or good luck with your experiment.
2. New set of lower ball joints, from the 1995-2000 LS400. These new ones will have slightly different geometry, and are different shape to allow for larger calipers which means you absolutely have to do an alignment after installing new LBJs. You may think that this is a good time to replace upper control arms, but it is not necessary, as those are two separate jobs all together (unless of course your UCAs are bad). You may want to replace the tie rod ends at the same time, they will be easy to do (They are also the first thing to bend if you hit a curb or a pothole - one of mine was slightly off, but not too much, so they compensated for that with an alignment).
3. The obvious stuff:
- New front rotors (I used brembo) for 1995-2000 LS
- New front pads (I used Wagner thermoquiet ceramic, because this combo worked great for me when I used to drive Acura Integra)
- DOT 3 brake fluid, better more than less, so 2-3 quarts (currently on special at O'Reillys!)
- Brake cleaner spray (handy to have anyway, sometimes there are good discounts on it, and that's when I buy it)
4. Tools that make all the difference:
- Jack (I have an aluminum racing jack and it is a life and back saver! got in on special at HF $69 during black friday)
- Stand(s)
- Electric or pneumatic impact wrench. I got a cheapo one at Harbor freight and it worked well for me. ($39 currently)
- Wrenches as well as impact sockets of these sizes (I hope I don't miss any): 10, 14, 17, 21, 24mm (or 15/16ths if you cannot find a 24mm - Harbor Freight sells 15/16ths impact socket for around $2-$3) - you will need it for your main nut on the bottom of the lower ball joint.
- Electric sheet metal cutter of some kind (again I bought mine at HF for $40 on special)
- C clamp to push back the brake pistons
- piece of wood to put across the pistons to avoid damaging them with a clamp
- Torque wrench (everything is around 50-120lbs/ft)
- A few 1/2in extensions, those with a rounded end as they allow you more freedom when trying to stick your impact wrench in tight spaces in the wheel well.
- Napa syl glide:
http://www.napaonline.com/Catalog/Ca...351_0361177638
- Depending on how badly the two little screws that hold the rotors are stripped and/or siezed, you probably need a tool for etracting such screws. I bought this one at HF:
http://www.harborfreight.com/12-piec...set-95530.html
and I used the two smallest sizes - they worked well for a few screws, but they are not the top quality, and they got dull quickly, but I hope to NEVER have to use them again, as that part of the job took the most time. Mine were so badly overtoqued that the center of the screw head was concave towards the hub, and it is supposed to be flat! If you want better quality tool for stripped screws, Autozone sells square ones - you first drill a hole in the screw (using cobalt-steel bits!), and then hammer the square profiled tool into that hole. After that it should be relatively easy to unscrew it with that tool pushed in.
- Braker bar. I have a 12" one, and I had to use it on almost everything when I was removing lower ball joints as a lot of bolts were torqued to over 200lbs! One of the bolts was so tight that I had to use a 5ft steel pipe extension that I have for just such case.
To be continued...
Old 05-28-14, 07:04 PM
PureDrifter
BahHumBug
Forum Moderator
PureDrifter's Avatar
1- only '95+ LS400 16s will clear the later brakes. '93-94 16s will not.
apham8 (11-19-23)
Old 05-28-14, 07:28 PM
peterls
peterls's Avatar
So, the first part of the job is installing lower ball joints. I would not plan on doing absolutely everything in the same day, unless you are a pro with a pro shop and access to all possible tools and toys one can imagine. Do not plan on driving on your old 15" wheels with new ball joints! It is impossible, and they will scrape against your old wheels like its the end of the world. So, even for this first step, you must have your new wheels already installed, or ready to install.
Go to this link and see how to change lower ball joints, it is the best write-up with pictures and all:
http://us.lexusownersclub.com/forums...er-ball-joint/
(i think you need to register with them to see the pictures)
Here is a funny thing: I took my car to a pro mechanic in a highly recommended shop, a guy who drives the exact same car himself - 1st gen LS400. He lifts it up, and checks the suspension and tells me that upper control arms need to be changed, but lower ball joints are OK.
I replace UCAs only to find out that old ones were very likely just fine (and they were OEM too!). However, Lower ball joints, especailly one of them, had quite a bit of play in it. So he missed that too.
Once you get lower ball joints replaced, you are ready for the brakes. I bought mine from a pick and pull place. If you are close to Sacramento, they have tons of those places there. Your Craigslist should also have good amount of listings from junkyards, but avoid private sellers unless they really have a good deal - I bought all four calipers with all hardware (and almost new pads already in them!) for $200, shipped. That comes to about $50 per corner.
Things that are the same between gen 1 and gen2 brakes:
- Same size of bolts all over: identical banjo connector and bolt where the brake line connects to the caliper. However, even if the bolts size are the same, their length (except for the banjo one) is not! The new calipers use shorter bolts, and if you don't have them in your new calipers, you must order them from Lexus. Some parts store may have them, but in my case O'reilly's thought they had them, and when I bought them they were completely wrong part - luckily I had them in the new calipers as well so I used those.
- Almost the same length of the brake line, but 2nd gen is longer by about 1 or 2 inches, so do not plan on reusing the old ones, they will be too tight in there when wheels are turned to extreme! Since these cars are old, we should all plan on replacing our brake lines, I prefer stainless steel ones.
- Same position of holes for two bolts that hold the caliper to the steering knuckle. So it is a direct bolt-on.
Things that are different: everything else! Pads, even those little wires/springs, the whole deal is different. Setting old pads in the old brakes was a little finicky, just because they are so small and really junky. The new ones, from 2nd gen, you will see - they are quite a nice piece of work, everything sits in properly and just right. To me they seem to have a bit more travel, and that reflects on my brake pedal feel... or maybe I just need to bleed my brakes a bit more? Don't know.
The procedure to install new front calipers and pads is this:
1. Get those wheel nuts loose before you jack up the car
2. Jack up the car and put it on stands (if you are doing both sides at the same time, you can jack it up in the middle, by lifting at the crossmember, the weight on your jack will be around 2000lbs)
3. get the wheels off
4. Unscrew the two 17mm bolts on the back of your caliper - they hold the caliper to the steering knuckle. They are both impossible to see, you literally have to turn the left wheel to the right, or right wheel to the left, to be able to stick your head in there and see them just barely. If you can see them easy, they are not the ones. If you turn the wheels all the way, the electric impact wrench from HF may just fit in there to save you a bit of time. Or if they are overtorqued, you may have to use a braker bar - mine has a good joint that allows me to bend the bar outside of the wheel well and then i can put a really good amount of weight on it. These need to be torqued to 87 ft.lbs.
5. Now the caliper can come off. Leave it on a tool box,or an upside down bucke or whatever you can put under the wheel, or tie it to the spring, with a wire as it is heavy. Do not remove it from the brake line yet, you will loose too much brake fluid.
6. Now you have one thing in your way: the dust shield. It is very soft metal, you can bend it with your hands. The top I just pushed with my bare hands. The bottom part is a female dog. So I took my electric shears and just cut away that part - start from the thin edged end which is towards the front of the car and cat across all the, to remove the whole bottom part. WIht right tools, iti is easy; without them, you can spend hours banging and guessing and constantly trying to put on the new rotor.
7. Once that dust shield is out of the way (don't worry, others have taken it off all together, and they report no problems!), you have enough space to put the new rotors there. Don't forget to wash the new rotors with brake cleaner spray after you put them! I recommend you use new little screws if you are using them at all; there are two per wheel, and they cost around $1 ea. at any Lexus dealership. The part number is: 90155-60002
They are NOT an essential part, and people drive without them. But they do make your life easier when working on brakes.
8. Get the new caliper, and study it a bit: it has that funny thin metal piece that goes around the bolt to make your life living hell when you try to bolt them in. I almost tore the little piece away as it took me 15 minutes just to get the bolt in because the little thin piece of metal bends as I put on the caliper and ends up being in my way and covers the bolt hole. If it was all new, this would not be a problem, but mine were all bent out of shape... If you have the same problem, you have to stick your head in the wheel well and push it out of the way with a screwdriver that you put in the bolt hole.
the new RIGHT caliper also has that funny looking wire clip, part number 4774950020 that holds the pins, and a sensor. On my 1990 LS, there is nothing for that sensor, so I took it off. Without that spring you are screwed, so first check that you have it in there! If you don't have it, car parts stores can get it for you in a day. Just remember to tell them that you need it for, say , 1997 LS, not really your car! Here is a picture of both right wheel and left wheel clip:
http://www.google.com/imgres?imgurl=...tart=0&ndsp=32
Yes, they are different! (and each caliper uses two of those sliding pins pictured above, so you need four in total)
Check to see what you need as far as the rest of the hardware. My wagner thermoquiet do not use shims, they are built-in.
Clean the pins on the new calipers, and put some Napa syl-glide on them. There are other places where you may want to put Napa syl-glide, best to check it for your pads.
9. Use a piece of wood over the pistons and a C-clamp to push the pistons back in. Then, install new pads in the caliper. Unlike your old calipers and pads, these will sit tight and nice. This is the clamp I used:
http://www.harborfreight.com/6-inch-...amp-37850.html
10. Now, be quick: using 14mm wrench (or if the bolt is too tight use an impact wrench) and unscrew the banjo fitting end of the brake line that goes into your caliper. It will immediately start leaking brake fluid, but you knew that, so just put that line into the new caliper and tighten it right away. There is a crush washer there, so tiny that it is easy to miss. Ideally you should get a new one, but I just reused the one from my old calipers, they are identical.
11. Now, put the caliper on the rotor, and find those two holes to screw in the two bolts. You CANNOT re-use old bolts, the new ones are shorter. If you already turned the steering wheel in the opposite direction of the side you are working on, you should have enough space to put an impact wrench in there and screw it in quickly. These need 87 ft. lbs of torque.
12. On the top of the caliper there is a bleeder valve, covered with a black cap. If you lost it, you can buy one pack of those 5/16th inch vacuum caps and cut them to be shorter, they fit fine. Unscrew that valve (10mm wrench) and have someone pump while you are watching the brake fluid squirt out. We pumped a bit, and it didn't seem to take too much air in as I was working fast, so the brake fluid did not get a chance to leak too much.
And the rest is easy! Put back the wheel and try out the new brakes. With new pads and rotors, brakes need about 200miles for pads to be seated properly. The most important thing to remember is: do NOT brake hard, and do NOT stop and hold brakes on at traffic lights! Find an alternative way - use parking brake, or let the car slide a little in the worst case... but if you brake hrad and then keep the brake on, you will possibly get some of the brake pad material stuck to the rotor and get what people incorrectly refer to as "warped rotors" (they are never warped, just their surface is not uniform)
BTW, I just changed the brake lines on the front wheels and the 2nd gen are longer, as they should be, and everything bolts right on, except for one litle thing: the old bracket was too narrow, and the new, slightly wider end of the 2nd gen brake line does not fit in it. I just used a zip tie to hold it there, and it is just fine.
I hope that covers it, if not, I will edit this post later
Old 05-28-14, 07:29 PM
peterls
peterls's Avatar
Thank you PD, I didn't know that!
Old 05-28-14, 08:42 PM
qha_vn
qha_vn's Avatar
great write up, some images of procedure/ outcome would be appreciated
Old 05-28-14, 09:59 PM
Gene01
Gene01's Avatar
The LS430 wheels may also fit. I think that PD would know for sure.
Old 05-29-14, 06:20 AM
peterls
peterls's Avatar
I wish I took some pictures, but I promise to do so when I start working on brake lines which will be soon, to show as much as possible. It is really not a big job, if bolts and screws were not overtorqued, and if you have all the parts and tools; but it may be a big job if you are not ready for it.
Old 05-29-14, 10:27 AM
Shmee
Shmee's Avatar
You don't need this unless the screws are stripped. What you actually need is an impact driver and a BFH. This is what the pros use to remove/install those screws and why they are so tight! A good impact drive. Is like $20, I bought a husky one from Home Depot 16 years ago for $25 and I still use it. Broke a few tips but the tool still works!
Also, picks would help.
Your description on a few things is a bit fuzzy with out them!
Old 05-29-14, 06:12 PM
peterls
peterls's Avatar
I hear you about the pictures, promise to get them next time I go in there.
BTW, I tried impact driver on those screws first. The screw head was deformed and concave from too much pressure when they were screwed in, that's how bad they were; and they were stripped completely.
And even with the extraction tool which I put on my impact driver again, it took so much pressure that one of them gave in only after I have been trying to get it out for few minutes! And they were all soaked with PB blaster, twice - the night before and that day. Yes there are definite idiots out there that should never work with cars.
Old 05-29-14, 07:04 PM
Shmee
Shmee's Avatar
I don't know what to say...
In all my years, I have never met a screw that an impact driver couldn't remove... Only times I can think of is when one of my greener apprentices didn't switch his impact driver to "remove" and/or didn't strike it hard enough with a BFH. He basically noodled the drive side of the screw and then we either just drilled the head off or it just took a better strike in the right direction. I wasn't standing over your shoulder so I cannot say for sure but my guess is you either didn't strike it hard enough with a proper hammer or didn't hit it in the right direction.
I pride myself onrush precision of my "eye-crometer," so I'm not really sure how you could see deformation (beyond a buggered drive) or concavity over the face of a screw that's barely ½" across (if that) and doesn't have a uniform surface, let alone a brake rotor screw strong enough to deform the head without yielding at the neck first... These aren't structural screws we are talking about, they are grade-1 "locators" designed to hold the rotor on with the wheel off... That's some next-Level screws the last guy put on there to have such attributes!?
Anyhoo....
Great write up otherwise, now get some pics!
Old 04-01-24, 12:04 PM
growthroughlife
growthroughlife's Avatar
Digging up this old post to see if anyone would be able to assist me in my thinking.
I am trying to rebuild my entire front suspension on my 92 LS400. I was able to purchase everything I needed, except for LBJs. I’m wondering if I would be able to install the 95-97 LBJs on my 92, given I have big enough wheels.
The wheels that were on my car when I bought it came off of a 2002 GS460. The dimensions are 16 x 7.5 50mm offset. The wheels on the 1995 LS400 that are needed for this mod have the dimensions 16 x 7 45mm offset. So would the wheels I currently have be compatible? I don’t see why not, but please correct me if I’m wrong.
Old 04-01-24, 08:45 PM
timmy0tool
Forum Moderator
timmy0tool's Avatar
based on https://www.1010tires.com/Tools/Wheel-Offset-Calculator
the GS wheels will be 11mm more inward towards the center of the car, and 1mm outward. both are very minor and should clear just fine.
Old 06-08-24, 08:40 AM
MYourg45
3rd Gear
MYourg45's Avatar
Default You’re the man
- Stand(s)
- Napa syl glide:
To be continued...
10 years later and this post is the reason I’m making a clublexus™️ account.
400fanboy (06-08-24)
dicer
18
07-18-15 10:48 AM
SC2JZ300
Suspension and Brakes
06-08-09 05:31 PM
ur2slow1
01-15-09 12:52 PM
350z
10-22-03 04:51 PM
Quick Reply: Definite guide to upgrading 1st gen LS400 front brakes to 2nd gen
