Air conditioner issue? Ls400 '94.......
Old 05-08-14, 09:36 AM
OMAHA
OMAHA's Avatar
Default Air conditioner issue? Ls400 '94.......
yesterday i ran my A/C and after i turned my car off and went inside for about 20 minutes, i came out and noticed a small pool off water had dripped down near the front driver side wheel. when i started the car it sputtered which was unusual and sputtered for a block or two. then it ran smooth and has ever since.......of course i'm scared to turn on the A/C now.....lol......any ideas what happened?
Old 05-08-14, 09:48 AM
sha4000
sha4000's Avatar
Did you see water or anti-freeze? I ask because there is a drain house that drains water under the car when the AC is on. On the 98 I believe it's on the passenger side though.
Old 05-08-14, 10:16 AM
OMAHA
OMAHA's Avatar
it was water, i swiped my finger on it and smelled it....it looked clear, no smell, kinda of greasy, oily feel though...
Old 05-08-14, 10:41 AM
sha4000
sha4000's Avatar
Then that's normal for the AC but I don't know what the sputtering is about. That might be a separate issue. Turn the AC on and see how it runs.
Old 05-08-14, 11:46 AM
OMAHA
OMAHA's Avatar
ok thanks.....i will keep you posted!
Old 05-08-14, 12:41 PM
OMAHA
OMAHA's Avatar
ok, when i started it today the "coolant low" light came on, so i put about a half pint of coolant in to bring it up to the "cold level"........maybe this is related to my issue!
Old 05-08-14, 02:13 PM
timmy0tool
timmy0tool's Avatar
yes, the AC condensates the lines and water purging is completely normal, but as stated it's on the pass side a bit behind the front tire near the middle of the car.
now to find why the coolant was low to start with. find that leak!
Old 05-08-14, 03:00 PM
sha4000
sha4000's Avatar
Have you watched the temp gauge to see if it's not where it normally is? I hope that was Toyota coolant that you topped it off with.
Old 05-08-14, 04:29 PM
OMAHA
OMAHA's Avatar
temperature gauge is fine, and i only use toyota red coolant.....top off with "pink"
Old 05-08-14, 07:02 PM
sha4000
sha4000's Avatar
Being low on coolant can actually shut your car down if it's low enough to protect your engine but you would see the temp gauge start to rise. Just drive it like normal and pay attention to how it performs closely.
Thegamemhb
06-30-19 03:31 PM
Neogenic
09-29-14 07:40 PM
94Blexus
SC- 1st Gen (1992-2000)
06-27-13 08:50 PM
shine
Maintenance
07-17-07 10:52 PM
HMCGARY
04-13-03 12:10 AM
Quick Reply: Air conditioner issue? Ls400 '94.......
