Aftermarket steering wheel and cruise/airbag
Old 04-22-14, 07:21 AM
Greg5OH
Greg5OH's Avatar
Default Aftermarket steering wheel and cruise/airbag
IM thinking about getting a nice Nardi wheel. Dont like the massive schoolbus ls400 wheel. But still weighing options.
What to do with eh cruise control stalk?
If i disconnect the airbag will I have a light on?
something like this:
or:
Old 04-22-14, 08:09 AM
sha4000
sha4000's Avatar
I'm pretty sure the airbag light will come on if you disconnect it and then turn the car on. Is there a work around? Maybe I don;t know but there should be plenty of threads where guys are running after market steering wheels and the answer should be in one of them.
Old 04-22-14, 09:22 AM
YoshiMan
YoshiMan's Avatar
Just remove the gauge cluster and take out the bulb for the light. What difference does it make at that point?
Old 04-22-14, 12:09 PM
timmy0tool
timmy0tool's Avatar
keep in mind that removing one air bag disables the whole SRS system (all air bags), hence the warning light on the dash.
in my hondas, i've had success installing a common resistor in the wiring to trick the system into thinking the air bag is still there. this continues to enable the passenger side airbag to still function in case of a collision (plus no warning light). it is unknown to me if a similar solution can applied for lexus cars.
as for cruise control, it depends on the adapting hub which will need to retain the clock wiring. then you have to figure out a way to retrofit the stalk on the hub/wheel since the on-off switch is on the stalk itself. i have not seen it done yet.
wmj259
04-27-19 04:54 PM
pretzelmak
GX - 1st Gen (2004-2009)
08-23-14 11:29 PM
Meunvmost
SC- 1st Gen (1992-2000)
08-27-11 03:36 PM
MySc4fever
Performance & Maintenance
10-05-10 06:08 PM
sc400 2nv
05-08-07 04:53 PM
Quick Reply: Aftermarket steering wheel and cruise/airbag
