just got a 95 ls400
Old 05-03-14, 01:29 PM
  #31
sayow
sayow's Avatar
Originally Posted by Blksmyth
Just cant leave it stock so the 5 speed is under way.
i picked up a is300 manual transmission. Sold the 1jz bell housing.
Bought a adapter for 1uz to w58 (TV8). Extended the shifter back 4+inches. (my fabrication experience)
Got a pedal at pick a part from an 83 toyota pickup master cyl from JEGS ( wilwood)
Project near completion very clean factory look through out!
Didnt have to move the fuse box well...(just a little), booster or e brake!
Easy swap so far cant wait to roll!!!
This makes me sad... no offense but Civics and Integras are for modding... but a beautiful LS.
Old 05-12-14, 07:43 AM
  #32
Blksmyth
Blksmyth's Avatar
Speedo works! 65mph 2300 rpms! 5th gear...awsome!!!
Old 05-12-14, 09:24 AM
  #33
IBGREEZY
IBGREEZY's Avatar
Yeah Buddy! Did you use a Toyota speed sensor? I talked to my buddy with the LS gauge cluster in his Cressida/1UZFE, and he said he just used an old Toyota speed sensor and it will read accurately.
Either way I'm glad you got your cluster communicating with your VSS
Well done mate.
Old 05-12-14, 09:27 AM
  #34
IBGREEZY
IBGREEZY's Avatar
Uh..........this whole forum is filled with "modded LS400's"
Old 05-19-14, 07:51 AM
  #35
Blksmyth
Blksmyth's Avatar
yep.... it was a good car as a automatic but is great car as a manual!
Old 05-19-14, 07:56 AM
  #36
Blksmyth
Blksmyth's Avatar
Well done mate.
yes! Toyota sensor was used with a magnetic collar from Race Pak in California.
Old 05-19-14, 08:11 AM
  #37
Blksmyth
Blksmyth's Avatar
Right on. Congratulations brotha. What drive shaft did you use? A combination of the W58 and stock auto LS??? Or did you buy a custom one piece? I was wondering what would happen if I left the auto tranny sensors plugged in to prevent CEL's, did you try this? Also what RPM's are you at @80 mph? I'm debating on just going 6speed to save gas and not be so high in the RPM range while freeway cruising. I've driven a buddy's 1UZ 85 Cressida with a W58 and was surprised at how effin great the 1UZ felt bangin through gears. I know how you feel right now, somewhat. From what I understand the KA tranny will have me above 3000 @ 80 mph, so I'm considering a 5 speed with taller 5th gear or 6 speed. Time for some research. Anyways congrats again, Oh and video or it didn't happen...lol.
Well we removed and flipped the drive shaft around leaving the slip joint between the rear end and the center bearing leaving the front drive shaft fixed at the bearing ( not allowed to move forward) eliminating possible trans rear seal damage and loosing 60.00 dollar a gallon trans oil..
I got my degree on this at hard knock university...lol.
im just sayin...lol
Short story.. flipped the shaft welded the rear yoke on the front and front yoke on the rear shaft and..... perfection!!!
Old 05-19-14, 10:32 AM
  #38
Shmee
Shmee's Avatar
Nice work. I just saw this thread but as I was going along I was saying why not just make a simple trigger wheel and mount it external to the trans or diff! And bang, that's what you did!
I would have waterjet something out of steel in a similar pattern as stock and mounted it pretty much the same as you did.
sututututu
GS - 1st Gen (1993-1997)
04-03-17 07:23 AM
RcklsLexus
10-24-15 03:53 AM
Yohan84
SC- 1st Gen (1992-2000)
09-03-14 01:08 PM
scfou
SC400 / 300 Classifieds
12-04-09 05:26 PM
xtrmboost
Performance & Maintenance
18
01-29-08 09:29 PM
Quick Reply: just got a 95 ls400
