1994 Lexus LS400 MAINTENANCE
Old 02-23-14, 03:53 PM
jgresh1101
jgresh1101's Avatar
Default 1994 Lexus LS400 MAINTENANCE
Replace my spark plugs and ignition wires Friday. Found autolite platinum spark plugs in engine. Plugs slightly worn. Two of the spark plugs were loose. I removed them by hand . Ignition wires look ok but who knows when they were service. Replace with denso wires and ngk plugs. The engine has a smoother idle, slightly better acceleration and quieter at idle. PREVENTIVE MAINTENANCE IS EVERYTHING
Old 02-23-14, 06:29 PM
RA40
Super Moderator
RA40's Avatar
Fluids next. Tranny, differential, brakes and coolant with thermostat.
Old 02-23-14, 06:55 PM
python
python's Avatar
and thermostat housing..it is plastic
Old 02-24-14, 03:28 PM
jgresh1101
jgresh1101's Avatar
Changing 2 quarts of transmission fluid with every oil change. Transmission fluid was pretty dark. Switch to syn oil an it seems to make the engine quieter. But M1 in my 1992 honda and it made it sound like a sewing machine.
Old 02-24-14, 04:05 PM
YoshiMan
YoshiMan's Avatar
Sewing machine good, or Sewing Machine bad?
Old 02-24-14, 05:52 PM
jgresh1101
jgresh1101's Avatar
sewing machine bad. noisy when outside temp is cold. Quiets down after the engine reaches operating temp. Why replace the thermostat??.. Temp gauge seems to be reading ok. Plenty of heat.
ThumperPup
ES - 5th Gen (2007-2012)
03-31-15 05:37 AM
TLsc300
SC- 1st Gen (1992-2000)
08-28-10 04:57 PM
MidTownMan
04-03-10 11:10 PM
parnzen
Performance & Maintenance
08-16-07 11:54 PM
ShowGSLuVv
Performance
05-17-02 12:15 AM
Quick Reply: 1994 Lexus LS400 MAINTENANCE
