My UCF21--What does this dash light mean ?
Old 02-07-14, 10:25 PM
MattLS400
MattLS400's Avatar
Default My UCF21--What does this dash light mean ?
Members,
I seek clarification of what this dash-light means..It appears a little while after driving, then it just remains there...
Attached Thumbnails My UCF21--What does this dash light mean ?-2014-02-07-16.19.55.jpg
Old 02-07-14, 10:57 PM
hirosada
hirosada's Avatar
Something is up with your brakes.
Old 02-08-14, 12:14 AM
LScowboyLS
LScowboyLS's Avatar
it means your brake pads are near the minimum thickness and need to be replaced
Old 02-08-14, 01:10 AM
Yamae
Yamae's Avatar
Also below will turn on the light.
Low brake fluid level,
Parking brake switch failure,
Brake booster failuer.
Old 02-08-14, 04:14 AM
MattLS400
MattLS400's Avatar
Thanks Guys....Its really been a while since ive checked my disc pads
Old 02-08-14, 01:21 PM
Gene01
Gene01's Avatar
If it is the pads, the sensor will have to be replaced to turn the warning light off.
Of course, you could short the wires together, but that defeats the purpose of the warning light.
Old 02-08-14, 01:57 PM
LScowboyLS
LScowboyLS's Avatar
I think you mean the sensor will have to be "put back in place" - he doesn't need to "replace" it, in the sense of buying a new one
Old 02-08-14, 04:29 PM
Gene01
Gene01's Avatar
My understanding is that the sensor is a loop in the end of the wire. When the pads get thin, the wire is worn through by the disc and opens the circuit. Therefore, the sensor would have to be replaced to complete the circuit again and turn off the warning light. I think that this is what the dealer does when the brake warning light is activated (after replacing the pads). Perhaps it is possible to solder the tips of the wires together again, but I have not heard of anyone doing that successfully.
Is that wrong? If so, I will edit my previous post.
Thanks for the input.
Old 02-08-14, 04:31 PM
sha4000
sha4000's Avatar
The sensor wire usually breaks and opens the circuit when the pads get too low. At least that's what happens on my 98. sometimes if you catch it early on you can save the sensor but not likely. If you don't want to buy another sensor you can just take the 2 wires and close the circuit to turn the warning off. At least in the 98-00 models.
Old 02-09-14, 06:38 PM
Gene01
Gene01's Avatar
sha4000 - Yes, that is how I understand the pad wear warning circuit.
LScowboyLS - Could you confirm this? I don't want to post bad information. Thanks.
Old 02-10-14, 06:34 AM
MattLS400
MattLS400's Avatar
Thanks for the helpful support ! Cheers
Old 02-10-14, 10:11 AM
timmy0tool
timmy0tool's Avatar
gene you are correct and it could be possible to solder the sensor together for a quick fix. how much are the sensors anyway?
btw, i never noticed RHD spec cars have the temp and gas gauges reversed from their LHD counterpart!
Old 02-10-14, 06:40 PM
Gene01
Gene01's Avatar
If I remember correctly, some members have posted here that they are $65 each (could well be off $20 either way).
Old 02-10-14, 07:51 PM
Largefarva
Largefarva's Avatar
You are correct in this, but if the light is on you may as well just connect the wires since the sensors are inop anyways.
Old 02-11-14, 07:42 AM
sha4000
sha4000's Avatar
I bought 2 from rock auto a couple of months ago for like $7 apiece but i have not installed them yet. If they work and I have no reason to believe they wont I'm ahead, when I first looked for them at the online dealers a couple of years ago they were like $85. I just ended up closing the circuit and taping them up.
Quick Reply: My UCF21--What does this dash light mean ?
