Oil leaking from timing cover onto pan gasket?
Old 12-10-13, 12:38 PM
davincity
davincity's Avatar
Default Oil leaking from timing cover onto pan gasket?
So guys I figured out where my leak was coming from. I have a 1991 LS400, I cleaned the bottom and there was a snail trail from a little black box (timing cover?) above the oil pan gasket. My mechanic took it apart, replaced the crank seal, and he said the valve cover gasket wasn't leaking. Only thing I can think of is the cam seals?
I really need help with this, I had it serviced 3 times, they fixed an O ring, Crank Seal, and oil pan gasket, nothing worked! I'm just thinking what else could possibly be leaking oil. Also replaced the bearings in my drive belt tensioner and it's still squeeking.. is this because oil is leaking onto it? Any help will greatly be appreciated as I don't know cars to well. Thanks guys!
heidihidin
ES - 5th Gen (2007-2012)
08-22-18 11:05 PM
Murphydurf
GS - 1st Gen (1993-1997)
12-05-13 08:30 AM
Murphydurf
09-28-13 10:37 AM
KeniGS300
Maintenance
09-14-10 04:48 AM
tritron
Performance & Maintenance
06-30-09 06:49 PM
Quick Reply: Oil leaking from timing cover onto pan gasket?
